Old 01-10-06, 10:18 PM   #1
LAURENT VALLAT
Default 2006 SV650 WON'T START
IT TIPPED OVER STANDING STILL EVERYTHING CHECK OK WON'T TURN OVER.
IS THERE A KILL SWITCH FROM IMPACT??
ELECTRONICS TURN ON,BIKE IN NEUTRAL,CLUTCH DISENGAGED,WHEN I PUSH START BUTTON LIGHT DIMS BUT NO TURN OVER!!I CAN'T UNDERSTAND.IT WAS LAYING ON ITS SIDE 3 OR 4 SECONDS.JUST BENT THE SHIFTER.
Old 01-10-06, 10:20 PM   #2
hovis
have u checked the red cut out switch on bars
Old 01-10-06, 10:29 PM   #3
jambo
jambo's Avatar
Does the engine turn over?
Old 02-10-06, 12:16 AM   #4
Mesomorphman
You have to click the red switch on the handlebars off then on after a tip over, I believe.
Old 02-10-06, 09:42 AM   #5
Sudoxe
HAVE YOU CHECKED YOUR CAPS LOCK KEY?
Seriously though, under the seat there is a tip over sensor (a little square box), check that hasn't worked it way loose, the bike wont start unless it is upright.
Dan
Old 02-10-06, 08:28 PM   #6
sv650nutter149
i know what the problem is when u turn everything on does it make a wizzing sound of the fuel injectors then if not just turn the bike on and off a couple of times and it should work then it will probably say ecu fault or something. the same happened to me on my k5 when i first dropped it.
any problems just ask.
Old 02-10-06, 08:31 PM   #7
hovis
Dan
Standard 2006 SV650 Can G For Sale - SV's and SV related items 2 23-06-08 03:36 PM
2006 Sv650-s david-m For Sale - SV's and SV related items 1 28-05-08 06:23 PM
Sv650.org's What? can 2006 neilhatch Exhausts 4 22-11-06 04:34 PM
FIGURED OUT WHY 2006 SV650 WON'T START LAURENT VALLAT SV Talk, Tuning & Tweaking 17 04-10-06 02:28 PM
Just bought a new 2006 SV650 ohiobiker SV Talk, Tuning & Tweaking 2 24-04-06 12:11 PM
