Old 08-10-06, 09:14 PM   #1
Ed
Default How often should I tighten the chain?
I ask only coz I've done it on the 'tona for the first time in 2,300 miles. It never seemed to need adjusting before. Bit fiddly too so I hope I don't have to do it again for a while.
Old 08-10-06, 09:20 PM   #2
fizzwheel
fizzwheel's Avatar
When its slack...
Helpful aint I
Depends how much you ride and how heavy you are with the throttle and how well lubed etc your chain is.
I've done about 9000 miles on the GSXR now and I've never adjusted the chain.
Liz never adjusted the chain on her SV until the chain got into the last 500 miles of its life when it stretched badly and needed replacing.
We've both got Scotoilers which helps though.
Old 08-10-06, 09:24 PM   #3
Flamin_Squirrel
Yep, as fizzy says, when it needs it.
You should expect to be adjusting them the most at the start of their life when they're bedding in from new, and towards the end (providong the sprockets don't wear first) when they're on their way out.
How to tighten rear suspension on 01 sv650? RGSPro SV Talk, Tuning & Tweaking 22 13-09-12 06:21 PM
Pointy mirror pivot won't tighten thor SV Talk, Tuning & Tweaking 4 01-10-08 11:56 AM
Morax Gold Chain Wax / Wurth Chain Wax glade Ancillaries 3 14-02-08 06:41 PM
How to tighten / loosen round nuts on steering stem?? Khewett SV Talk, Tuning & Tweaking 4 14-05-06 09:33 AM
Will stiff chain link cause chain noise dclifford SV Talk, Tuning & Tweaking 8 16-08-05 11:56 AM
