I'm collecting my K4 SV on saturday, cant wait!! I'm wanting to fit an aftermarket can asap as my friend had a renegade on his curvy and sounded unreal!!
![]() I'm been looking a quite a few sites such as yosh, blue flame, leo vinco etc and have a question about the fitting of these cans. Most of the systems come with a slip on pipe and say you have to cut the original exhaust, is possible to get a can that simple bolts on in place of the standard can or is the standard can welded on instead of bolted ![]() Thanks for any advice you may be able to offer. |
You have to cut the pipe or get a system.
Ps, use the search facility! |
As you suspected the original exhaust is all one (well except the stub pipe), so the choice is either a complete system or cutting and fitting a slip-on, the cutting is no problem and has been dcovered extensively (do a search for details).
Cheers Mark.
Ok thanks guys, i'll do a search now and have a read up. Cheers
02 carbs and Carb Fittings | drag | Stuff Wanted | 1 | 01-02-08 01:12 PM |
Hugger fittings | 5v5 rider | SV Talk, Tuning & Tweaking | 6 | 24-11-07 08:49 PM |
Oil cooler questions..pipe fittings | svrash | SV Talk, Tuning & Tweaking | 1 | 17-08-07 07:47 AM |
Bulb fittings | Jester666 | SV Talk, Tuning & Tweaking | 2 | 22-05-07 07:57 PM |
Exhaust fittings | Bear | Exhausts | 0 | 30-07-06 02:47 PM |
