Old 22-10-06, 03:06 PM   #1
bad_hat_harry
Default Heeeeelllp!!! Trying to strip forks down.
Hello,
I'm trying to strip down the forks from my curvy 650 ('99). Never done it before, but there's a first time for everything and all that. Got the forks off the bike no problem. However, I'm trying to loosen the 8mm hex bolt (the Haynes manual calls it a 'damper rod bolt') at the bottom. Neither 1/2" or 3/8" hex sockets will fit into the hole to get to it and an allen key doesn't seem to have enough leverage longways on. I assume these bolts have been loctite'd in, so are going to need a bit of leverage to release. I'd also like to torque them up correctly when I rebuild it.
Does anyone know where you can get sockets with extra long hex bits? I've tried Halfords and Machine Mart.
Failing that, any other suggestions for getting these buggers out?
Thanks!
Old 22-10-06, 03:10 PM   #2
TSM
The Sick Man
TSM's Avatar
Use the spark plug extention bar to get levarage on the allen key end, thats what i do.
Old 22-10-06, 03:11 PM   #3
fizzwheel
fizzwheel's Avatar
I just used a Normal Allen key, I used the long side of the Allen key and put that onto the bolt, that left the short bit of the allen key poking out of the bottom of the fork. I then used a long piece of hollow tube and stuck that on the end of the allen key a bit like you'd use a break bar and that gave enough leverage to crack the bolt and I was able to undo it just using the allen key.
Old 22-10-06, 03:20 PM   #4
weazelz
I put an 8mm ring spanner on the long bit of an allen key & slide it up to the bend to give a lever
Old 22-10-06, 05:31 PM   #5
Blue_SV650S
I use the 8mm spanner trick (and a blow with a hammer) to get them undone. If you want to torque them up then you either need a long allen socket, or another way is to just chop the end off the allen key and use it with a 8mm socket on a torque wrench.
Old 22-10-06, 06:50 PM   #6
bad_hat_harry
Default Thanks!
I'll give the 8mm spanner trick a try! Cheers for the wise words
Andy
how to strip paint...... Wideboy Idle Banter 5 09-10-08 06:03 PM
Anyone know how to strip the audio from an .avi file? northwind Idle Banter 12 16-07-08 07:13 PM
Rear wheel strip down andyb SV Talk, Tuning & Tweaking 2 03-05-06 01:04 PM
Took the SV to the drag strip khskenny SV Talk, Tuning & Tweaking 89 12-05-05 08:56 PM
Visor and this strip thing?? The Mass Bikes - Talk & Issues 3 17-04-05 04:46 PM
