Now I know that an imbalance in the amount of air going through each throttle body can cause the bike to run badly - just the same as with the carb'd version of any engine.
BUT, is it possible to balance them at home, AND is it easy? Just found out how much a few companies want to charge me, and I'd like to spend some of that money on new tyres.... |
Vaccum gauges - £30. That's all you need.
I have a set for sale = £15 delivered. As new -used once.
PM if interested. Thanks Luke |
The front vacuum is fiddly to get to, but that's it. 1 hour tops and the results can be massive.
Right, so I need vacum guages, but how, where, and how do I balance?
edit: This is on a K3 - if of any interest............... |
I'm about to attempt to do this, any info would be appreciated on how you got on.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
Throttle body balancing | RingDing | SV Talk, Tuning & Tweaking | 22 | 29-04-09 02:12 PM |
Throttle body synchronisation K3 | muzikill | SV Talk, Tuning & Tweaking | 23 | 23-01-08 06:35 PM |
Balancing Carbs/Throttle bodies | tomjones2 | Bikes - Talk & Issues | 6 | 06-07-07 10:07 AM |
Throttle balancing - Friday night job? | BillyC | Soho Massive | 15 | 15-04-05 04:36 PM |
Throttle body diameter | danci1973 | SV Talk, Tuning & Tweaking | 1 | 05-12-04 11:34 AM |
