Old 25-10-06, 01:22 PM   #1
Paws
Default Front brake help....(not having much luck)
Ok ok i know im not having much luck with my sv but seeing as you guys are sooo lovely.
Front brake-basically i dont have one! (no im not riding her like it!)
Braided goodridge hoses-bled 3-4 times
Caliper seals replaced
new pads
Lever comes ALL the way back to the bar BEFORE itl start to stop!!!!! , master cyclinder me thinks? anyone else?
Old 25-10-06, 01:24 PM   #2
Blue_SV650S
Default Re: Front brake help....(not having much luck)
new pads
You have changed quite a lot there ... were they changed in one go and did these problems arise after changing everything or did it work and now just suddenly stopped?
Old 25-10-06, 01:30 PM   #3
Paws
Probs were there BEFORE it was all changed. we were trying to find out whats up with it.
Old 25-10-06, 01:36 PM   #4
Blue_SV650S
Presuming everything has been done properly (sometimes it is really difficult to get a good bleed) indeed the only thing left in the system is the master cylinder!!!
Just to check it isn’t an airlock, try ‘reverse bleeding’ the system … this can be done with a syringe full of brake fluid on the bleed nipples.
Another little trick is to pump the leaver until the pistons are virtually drooping out of the callipers (after removing callipers and pads obviously (and keeping and eye on the reservoir to prevent from going dry)) and then pushing them in, this then moves any air bubbles upwards and out through the reservoir … obviously it is easier to clear bubbles going up than down (as you would in normal bleeding).
Old 25-10-06, 01:40 PM   #5
jambo
jambo's Avatar
I have to go with air in the system assuming that the master cylinder seals are ok. Sometimes it can be useful to use the top banjo bolt attaching to the master cylinder as another bleed nipple, pumping the system up to pressure, holding the lever against the bar, and loosening, then tightening the banjo bolt, sometimes air stuck there just doesn't want to come out.
Old 25-10-06, 01:43 PM   #6
Paws
Cheers guys.
see this is why i love this site as youve all got the time and patience to suggest stuff and help me out.
Old 25-10-06, 01:43 PM   #7
I'd go with the syringe bleed as well, works a charm... Best way I've found so far in fact. Squirt, squirt, done.
Old 25-10-06, 01:44 PM   #8
Alpinestarhero
Has it worked yet paws?
Matt
Old 25-10-06, 01:47 PM   #9
jambo
jambo's Avatar
Cheers guys.
see this is why i love this site as you've all got the time that your boss is paying you to do some work, and you're happy using it to help people with bike problems instead!
Old 25-10-06, 01:51 PM   #10
Viney
Ok then my little bleeders...what kind of syringe do you use? One off the local car park druggie, or something a little more sustantial?
Front Brake - Rear Brake? Stradders Bikes - Talk & Issues 35 17-09-08 04:44 PM
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Good luck/Bad luck....All about being lucky innit 21QUEST Idle Banter 2 17-03-07 12:32 PM
Front brake not activating brake light properly SVeeedy Gonzales SV Talk, Tuning & Tweaking 5 27-02-07 12:09 PM
brake light flickers when the front brake pulled in - K4 dclifford SV Talk, Tuning & Tweaking 9 05-09-05 10:39 AM
