Old 06-11-06, 08:24 PM   #1
Blue_SV650S
Default Repair my corrupted files!
Took some more onboard video with my ATC1000 all in one cam. One session in particular was ace!! Sods law that was the one where the file is corrupted!!!
The file is still there ~170mb but comes up as corrupt if I try and run it. I presume the file as not ‘closed’ properly!?
Does anyone know of any software that I might be able to recover the file with. It’s a .AVI if that makes a difference?!?!
Ta
Old 06-11-06, 08:26 PM   #2
Carsick
http://www.google.co.uk/search?q=avi...utf-8&oe=utf-8
Old 06-11-06, 08:37 PM   #3
Blue_SV650S
Originally Posted by Carsick
http://www.google.co.uk/search?q=avi+fixer&start=0&ie=utf-8&oe=utf-8
Have you tried this ... I don't want to be downloading any viruses or spyware ...
Old 07-11-06, 09:23 AM   #4
Carsick
That's just google. There are loads of programs to do what you need. I haven't used any of them in about 5 years, though, so couldn't recommend any specific ones.
Old 07-11-06, 11:43 AM   #5
Baph
Ulead DVD factory will close AVI files for you. However, this might not be the corruption in the file, it could be elsewhere.
Nero might have a tool that could do it too.
Old 07-11-06, 11:46 AM   #6
TSM
The Sick Man
TSM's Avatar
VLC can fix some vids. www.videolan.net
Old 07-11-06, 03:37 PM   #7
Blue_SV650S
Nope, no good
I am uploading the file to the net as we speak ... you can then d/l it and give it a crack yourself if you are into this sort of thing, but I have drawn a blank myself
link to be posted shortly ...
Old 07-11-06, 03:38 PM   #8
SoulKiss
SoulKiss's Avatar
Bet I can get it fixed - I know this guy you see.......
Awaiting the Link
David
Old 07-11-06, 05:42 PM   #9
Blue_SV650S
here you go ladies and gentlemen!!! plz plz fix it for me
~170mb
http://www.sharebigfile.com/file/176...sion3.avi.html
oh and to get the file, just enter the security code thing near the bottom (presumably done to stop computer trawling?!?), hit the 'submit' button then it will let you d/l
Old 08-11-06, 09:46 AM   #10
SoulKiss
SoulKiss's Avatar
Latest update on the fixing
Originally Posted by Mike
David,
I haven't yet been able to fix the avi file. I'm not certain if my problem is compounded a little because I don't have an avi file that muxes MJPG video with IMA ADPCM audio so don't have a good header with which to compare. I'm not sure I have a codec that can decode MJPG but I'm sure that can be solved when the time comes.
I'm sure it should be simple to fix as I can see the file's composition, with
Audio : 7.30 MB, 44 Kbps, 11025 Hz, 1 channels, 0x11 = IMA ADPCM
Video : 162 MB, 995 Kbps, 20.0 fps, 320*240 (4:3), MJPG = Motion JPEG
I'll give it another go tomorrow. I'm starting to think the problem could in part be lack of the necessary codec rather than a damaged header. AviCodec doesn't baulk at opening it although GSpot does report a corrupt AVI header. I know I've managed to open files with damaged headers before now or at least demux them and then create a new file from the two streams.
Oh dear, the basic quartz.dll in Windows can decompress mjpg. Likewise imaadp32.acm can decode AMA ADPCM audio. So it must be the header. Will have to wait until tomorrow now.
Mike
Will keep you updated
Nero - just want to put files on a DVD! MeridiaNx Idle Banter 5 04-02-08 09:58 PM
X Files eviltwin Idle Banter 10 26-07-07 03:32 PM
Corrupted wishes Rog Idle Banter 41 22-08-06 09:46 PM
Rockford files cuffy Idle Banter 9 21-04-06 12:46 AM
SV End Can Sound Files I'm_a_Newbie SV Talk, Tuning & Tweaking 7 14-04-06 10:37 PM
