Old 12-11-06, 09:11 PM   #1
01 sv650s
Default clutch when starting
is there a way to iliminate the "pull in the clutch to start" device.
Old 12-11-06, 09:12 PM   #2
Razor
Join the 2 wires in the switch.
Old 12-11-06, 09:13 PM   #3
01 sv650s
where is the switch and is it easy to do
Old 12-11-06, 09:18 PM   #4
instigator
Left hand side switch control.
Easy to do, yes.
Old 13-11-06, 09:32 PM   #5
vulcan666
I wouldn't recommend doing it. You may ALWAYS remember to leave it in neutral, but two things can happen. 1) You can accidentally hit a false neutral (I'll admit I've not had that on my SV 650, but I have had it on other bikes) 2) Someone can mess with you and kick it into gear while it sits unattended. Then you'll hit the start and knock your bike down.
That said, your bike, it's all good.
Old 13-11-06, 09:37 PM   #6
hovis
Old 13-11-06, 09:38 PM   #7
hovis
Default Re: clutch when starting
Old 13-11-06, 09:48 PM   #8
suzsv650
yea u can do it on the cluch there is a lil box type thingi pull it off and goin the two conectors together ...
and also you wont start the bike in gear as the side stand switch is still there!!!
the bike will ONLY start in neautral!!!!!
sorry for spelling i cba lol
Old 13-11-06, 10:48 PM   #9
Bingo. Unless you park in a false neutral, I suppose, since the cutout sensor's the same as the neutral light sensor I think. But how likely is that?
Bypassing the switch means there's one less 2p electrical component to fail and leave you stranded in the middle of France... And removing the switch gives you an ever so slightly lighter clutch action.
Old 14-11-06, 11:24 AM   #10
Baph
If I go to france, I'll be carrying enough tools & wire to solve electrical faults on the bike (mostly).
Personally, I'd rather be forced to remember the clutch switch. If it develops a fault, I can strip it on the spot & temporarily bodge it.
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
Wow - Just starting out Grinch Idle Banter 38 29-11-07 06:05 PM
Starting (Clutch Override) Sideshow#36 SV Talk, Tuning & Tweaking 1 07-09-07 01:37 AM
hey new clutch advice Kyoto Clutch srxaus SV Talk, Tuning & Tweaking 3 14-08-07 04:25 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
