need to get a new shock, but cant really afford a pensake or ohlins. which range of gsxr shocks would be the best one to go for. i know this has been up a couple of times but i cant find it at the minute.
the year and model would be best. any other makes could be considered too. cheers |
Well it all depends--------Primarilly on what sort of bike you have got and what year it is.
ah yeees a very important bit of info that i forgot about. It would be a 99 model curvy 650. been looking at some gsxr1000 shocks, but unsure about ease oif fitting. not fussed about cutting the battery tray as that is reasonably easy.
I don't think they fit.What does fit is a Kwak zx6r or zx10r shock post 2003(I think)Look in the for sale bit,and Silent is selling one.He will also give you some good advice on fitting it.
#5 | |
<Swiped> YEAR MOTORCYCLE LENGTH SPRING ===== ========= ===== ===== 00-03 GSXR750 325mm 400# 01-03 GSXR600 325.5mm 325# 01-02 GSXR1000 329.5mm 430# 03-04 SV650 330mm 430# <<<==== stock 2nd gen...05 should be the same 99-03 GSXR1300(Busa) 330mm 700# 04 GSXR750 332.5mm 408# 04 GSXR600 332.5mm 425# 03-04 GSXR1000 332.5mm 480# 99-02 SV650 337mm 510# <<<====stock 1st gen 04 ZX10R 338mm 540# 03-04 ZX6R(636) 340mm 540# *corrected by e lo...thanks! 96-99 GSXR750 345mm 375# 97-00 GSXR600 375mm 375# 05 GSX-R 1000 332.5mm 450# <<<===added by me...spring rate from racetech.com, length from ohlins.com <end> |
#6 | |
i wiegh in at around 12 stone fully kitted.
I've a ZX-636 B1H shock spare.. but its had about 30K miles put on it.. so not quite as stiff as it once was.... and it needs a good clean at the moment...
Im not sure if you have to modify your bike slightly for it to fit anyway... somehting to do with teh battery ? |
#9 |
I weigh slightly
![]() Thanks! |
#10 | |
Standard rear shock. | Mark_h | Stuff Wanted | 8 | 22-10-07 03:22 PM |
Standard rear shock question. | Mark_h | SV Talk, Tuning & Tweaking | 1 | 21-10-07 07:07 PM |
sv 99-02 shock change | French | SV Talk, Tuning & Tweaking | 4 | 24-02-07 07:47 PM |
Curvey Standard Shock | Jase22 | For Sale - SV's and SV related items | 0 | 06-07-06 09:46 AM |
Just put the standard shock back in... | northwind | SV Talk, Tuning & Tweaking | 32 | 17-01-06 11:15 AM |
