I've lost the sound on my 'puter.
![]() Any ideas as to why this has happened? Could to two be connected? How do I fix it?? |
If this is only happening when you go to a web site with sound then it could be you've got the :
Menu option: Tool -> Internet Options -> Advanced -> "play sounds in Web Pages" tick box unticked. If this is happening all the time i.e. when attempting to listen to your favourite Bananarama CD then in your sytem tray on the desktop, look for the Speaker icon, select this then unselect the Tick box that say's, "Mute". Dirk |
#3 | ||
settings->control panel->sounds & audio devices
put tick in "Place volume icon in the taskbar" |
#5 | |
Many thanks. The speaker icon now resides bottom right. Clicking on it shows the mute box to be empty. ![]() |
#6 | ||
The Sick Man
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
Is the volume level set high enough?
Also, stupid questions I know but....is the volume for the speakers high enough? Are the speakers turned on? Is the speaker cable going into the correct socket in the PC? |
[quote="TSM
Double click on the speaker icon and check that the Wave is not muted and the level is turned up.[/quote] Non of the boxes are ticked (5 in total), and all the levels are at 3/4 max |
#9 | |
#10 |
OK rule out IE7 by installing it and going back to your previous version of IE.
I doubt its the IE7 ugprade though, What version of Windows are you running. Let me guess last time it worked fine and then you shut your computer down and powered it off and it hasnt worked fine since. If so I'd wager that you soundcard has a hardware fault and its broken. Either that or the soundcard drivers want re-installing.
Changing tyres. Pre problem, problem. | ooger | Bikes - Talk & Issues | 16 | 12-03-09 04:20 PM |
Broken Puter | Speedy Claire | Idle Banter | 20 | 02-06-08 03:52 PM |
'Puter/Printer help please | TT Dee | Idle Banter | 14 | 14-10-07 12:24 PM |
I need your help with this problem! | 1-3-2-4 | SV Talk, Tuning & Tweaking | 6 | 25-09-06 01:45 PM |
Battery problem / Alternator problem? | localhost | SV Talk, Tuning & Tweaking | 4 | 07-07-06 09:32 AM |
