Old 11-12-06, 02:51 PM   #1
krhall
Default Brake Fluid Resevoirs
I can't see how much is in there simply by looking at the side of them am I doing something wrong or is this common?
If so is it best to simply open the cap and look?
Also where is the rear one?
and where do I check the coolant levels?
Old 11-12-06, 03:43 PM   #2
Razor
Either the fluid is very new or missing, open and have a look.
I dunno about pointys, maybe the rear reservoir is under the seat.?
And lastly RTFM
Old 11-12-06, 03:45 PM   #3
krhall
Yes RTFM - It's much nicer to talk to the forum.........
Old 11-12-06, 03:55 PM   #4
Mogs
The rear reservoir is on the right hand side just above the heel plate, you should be able the see the level without opening.
Old 11-12-06, 04:12 PM   #5
andy
Not always, if the fluid is new it is pretty clear and if totally full then there is no line to see.
I have never seen a reservoir run out unless there is something seriously (eg obviously) wrong with the brakes....
Old 11-12-06, 04:16 PM   #6
krhall
So I've got no need to worry then?
What about the coolant?
Old 11-12-06, 04:20 PM   #7
thor
RTFM...
Old 11-12-06, 06:58 PM   #8
Flamin_Squirrel
Inside the reservoir is a black rubber seal - if you cant see the fluid level it's probably because this is in the way. Open the lid and you can push it back out of the way.
Old 12-12-06, 01:03 PM   #9
Mogs
Mmm, Hadn't thought of that, I can see mine.
Brake Bleed nipple/Mityvac/Brake Fluid query Ceri JC SV Talk, Tuning & Tweaking 15 20-01-09 02:04 PM
What Brake Fluid... DoubleD SV Talk, Tuning & Tweaking 10 03-03-08 11:21 AM
Dot 5.1 brake fluid DanF SV Talk, Tuning & Tweaking 2 09-04-07 03:15 PM
Brake Fluid & Oil krhall Bikes - Talk & Issues 6 20-12-06 12:58 AM
Brake fluid Trix SV Talk, Tuning & Tweaking 14 20-01-05 11:13 AM
