Old 12-12-06, 11:27 AM   #1
Baph
Default Anyone know any cheap PCB manufacturers?
OK, the scenario. I'm looking to make a modifided version of a project I did not that long back. I have the new circuit diagram, and I've tested the functionality fine. But I can't buy things until I know the final size of the PCB. I could go with a breadboard, but that's more succeptable to failure in the environment it's going to be used (the case will need waterproofing etc).
So, does anyone know any PCB manufacters that do one-off's pretty cheap, or possibly a run of something like 10 of them.
The circuit itself is a 555 timer linked to a 4000 series counter and a NAND gate, running on 12v. So a couple of capacitors, resistors, and the IC's, nothing major.
Old 12-12-06, 11:44 AM   #2
tigersaw
tigersaw's Avatar
Have you done the artwork yourself, or is it in a pc format like autoroute?
I remember having some pcb's made 20 years ago, and they cost £15 each back then for a batch of 10. It was so expensive I bought a uv light box and made the next lot myself. However, just after that wire wrapping became the new sliced bread. You could look at the range of stripboards, there are a lot more designs out there than just plain veroboard.
Old 12-12-06, 11:54 AM   #3
Baph
I've got various PC format spec's of it. Circuit diagrams, test schematics (that I can run & toggle switches etc so I know it works right), PCB layouts (in autoroute sytle and simple jpg's) etc.
The cheapest I've see so far is around the £23 mark for one, dropping to, as you said, £15/ea for 10. There is a chance I could make more of the devices, but at the moment, it'll only be for my use, so maybe one for use & one for spare. Because of this, I don't really want to be messing with the PCB etching kit I have at home, if I can find somewhere cheap enough to do it for me.
Copperplated stripboard is an option I've looked at for the prototype stage.
Old 12-12-06, 02:41 PM   #4
mysteryjimbo
Default Re: Anyone know any cheap PCB manufacturers?
Does it involve explosives???
Old 12-12-06, 02:50 PM   #5
Baph
Now there's an idea! That might work better than the original function idea. But I can't possibly comment on that!
EDIT: I'm also drawing up plans for a motion tracking projectile targetting system, but that's probably going to be on the drawing board & no-where else
Old 12-12-06, 06:29 PM   #6
svpilot
Aha! PCBs are my game
I use these guys for prototypes and small runs...
www.pcbpool.com
Good luck!
Changing Tyre Manufacturers Binky Bikes - Talk & Issues 26 25-04-09 09:34 AM
Two manufacturers out of WRC Gazza77 Idle Banter 1 16-12-08 01:27 PM
Manufacturers Fuel Consumption figures... 454697819 Idle Banter 5 02-07-08 03:48 PM
boring manufacturers names timwilky Idle Banter 13 27-02-08 11:17 AM
Links manufacturers manuals Tris SV Talk, Tuning & Tweaking 2 06-03-06 06:01 AM
