Old 17-12-06, 01:28 PM   #1
Ash999
Default Oil Diagnosis?
I noticed that the oil window on my gf bike was white so i pulled off the oil cap and there was froffy oil in there, like a cram white/yellow. After draining the oil I noticed that it must be contaminated with something? So I flushed it out and refilled it. Just wondering if this is something to worry about??
* note that as its my gf bike its not an SV but a Kawasaki ER500 R reg.
Old 17-12-06, 01:40 PM   #2
TSM
The Sick Man
TSM's Avatar
Water/Coolant
If it was the TL/SV then one way is for the water pump seal to have broken and leaking coolant into the oil or the head gaskets are gone. Now i am not 100% sure but i know that some TL peeps have had the pump gasket go. As this is not a TL/SV then it may not be that.
Old 17-12-06, 01:43 PM   #3
diamond
Could be a head gasket, i had mine go in my CBR 600 it looked like a mayonaise factory had exploded in my engine
Old 17-12-06, 02:03 PM   #4
Ash999
the exhaust is not smoking, runs fine, maybe slightly high pitched but btw its a kawa er5. Maybe coolant-how would that happen? as not into engines much
Old 17-12-06, 02:23 PM   #5
diamond
Does she do alot of short journeys?
Condensation caused by lots of short journeys where the bike doesn't warm up properly can cause the same but probably milder symptoms.
Old 17-12-06, 02:59 PM   #6
Razor
I got the same on my SV, I was only using it for 6 mile commute to work and back. Short distance syndrome.
Old 17-12-06, 03:00 PM   #7
TSM
The Sick Man
TSM's Avatar
My journey is far less than that and in the 2 yrs i have had the bike, never has the oil got milky.
Old 17-12-06, 03:45 PM   #8
on yer bike
Is this condensation dagerous to the engine? Ive noticed a little floating in my oil, and also my exhaust is smoking white, it hasn't been run for 2 weeks
Old 17-12-06, 04:08 PM   #9
diamond
http://www.ducati.net/faq.cfm?id=30
Check out this page on the ducati site, short and to the point.
Old 17-12-06, 04:12 PM   #10
on yer bike
thats exactly what I was on about, cheers e.d. *goes out on bike :P*
Speedo and diagramatic diagnosis! HELP! fenjer Bikes - Talk & Issues 5 20-04-09 08:29 PM
Diagnosis please - Battery vs Reg/Rec vs Other chris_c201 SV Talk, Tuning & Tweaking 19 16-04-09 10:50 AM
Pointy clocks diagnosis - am I right? Baph SV Talk, Tuning & Tweaking 10 02-04-09 07:49 PM
