Old 18-12-06, 08:44 AM   #1
Steve226
Default Rattling noise from front cylinder
I've begun to notice a rattling noise coming from the front cylinder of my bike (99 curvy sv650s). When sat on the bike its loudest on the left hand side of the cylinder. It's most noticeable when the bike is idling, as the noise of the bike drowns it out when i give it some rev's.
I was wondering if you had any idea's on what this might be and how it could be fixed? BTW. my exhaust can is cracked open however I believe the noise was there before this happened.
Steve
Old 18-12-06, 09:04 AM   #2
Spanner Man
Morning Steve.
Sounds like the camchain tensioner, quite a common problem on SV's! I think they're around the £50 mark.
Best to get it sorted, for if it gives up completely major damage can occur.
Cheers.
Spanner Man
Old 18-12-06, 11:59 AM   #3
Steve226
How difficult/dangerous would it be for me to do it myself? I'm reasonably technically minded, but I've never opened up an engine before.
Steve
Old 18-12-06, 12:05 PM   #4
mysteryjimbo
Steve
if you're not overly mechanically minded, get done by a professional. If you can only just change brake pads, this includes you!
Old 18-12-06, 12:36 PM   #5
Spanner Man
Hello Steve.
The tensioner can be changed without removing the cam cover, but I wouldn't recommend it. For there is always the possibility of the valve timing jumping, so it's radiator removal time.
The tensioner itself is a touch fiddly to get to, as the frame tends to get in the way.
The job is not beyond the experienced DIYer but the consequences if not done correctly are expensive to say the least.
Cheers.
Spanner Man
Old 18-12-06, 12:41 PM   #6
TSM
The Sick Man
TSM's Avatar
Mine are also a little rattly but only at realy high revs, like say 8k+, you hear a slight shrill.
Old 18-12-06, 01:55 PM   #7
Steve226
As much as i want to do most work on the bike myself I recon this might be a bit out of my league at the moment, so I'll get a professional to do it (it needs someone with some knowledge to give it the once over anyway).
Any idea how long it will be until this is a major problem? Currently I'm only starting the bike up once a week to stop it getting all gunked up, running it for 4-5Min's and then turning it off. I've still got stuff that I wanna do myself before handing it to a professional but i need to know how long i can really leave this?
Steve
Old 18-12-06, 03:00 PM   #8
Spanner Man
Afternoon Steve.
To be on the safe side I wouldn't run the engine until you have the problem sorted.
I remember a Firestorm I went to see that blew up when the customer insisted that he ran the engine to show me the rattle. BIG OUCH!!
Cheers.
Spanner Man
Old 18-12-06, 03:44 PM   #9
Steve226
Should I get it picked up to be on the safe side?
Steve
Old 18-12-06, 05:58 PM   #10
Spanner Man
Evening Steve.
To be on the safe side I would indeed get your bike collected, small price to pay innit!
Cheers.
Spanner Man
rattling noise at high revs. sketti76 Bikes - Talk & Issues 3 10-05-09 11:16 PM
Front cylinder noise andyb SV Talk, Tuning & Tweaking 9 10-07-07 05:27 PM
rattling noise paulthewitt SV Talk, Tuning & Tweaking 22 17-04-06 02:26 PM
Periodic noise in area of the forward cylinder jn SV400(650) Dimax3 SV Talk, Tuning & Tweaking 2 27-07-05 09:21 AM
Rattling noise - rear brake SpankyHam SV Talk, Tuning & Tweaking 3 05-05-05 04:35 PM
