Old 28-12-06, 10:45 AM   #1
Grinch
Default Problems with changing down multiple gears
I suspect its the oil breaking down causing odd things but this week the bike has started no changing down a gear. The exact symptom is as follows -
Occasionally when changing down a gear with the clutch fully pulled in I can move to the next gear down but if I try to drop another without releasing the clutch the gear select leaver moves but no selection occurs. So If I try to go from 6th to 4th in two selects it fails.
If I release the clutch between these selections then it all works correctly, so if I go 6th to 5th then to 4th i have no problems and it only seems to happen in high gears.
Now the bike is over due a oil change (to be done this weekend) and I have been riding her in some really crappy weather. Hopefully the change will fix it, but I am worried the select is going. If it is at fault how much of a big job is this to fix?
Old 28-12-06, 12:43 PM   #2
jonboy
Hmm, do you normally blip the throttle as you change down?
Old 28-12-06, 02:18 PM   #3
Grinch
On single changes I think yes... but this is when I've slowed down alot, say via breaks and then had to drop down a few gears to match my new speed. Or if I trying to scrub off alot of speed but not with the brakes, and drop 2 gears on one go.
I think...
Old 28-12-06, 02:45 PM   #4
jonboy
Well my experience of sequential gearboxes is that they don't like being asked to change down at low speed/revs, particularly if you're block changing. Give it a good blip for each cog you want to swap and see if that helps — or just ride better and be in the right gear in the first place .
Old 28-12-06, 02:51 PM   #5
Grinch
That is true, but I've not ever noticed it before.
Old 28-12-06, 05:14 PM   #6
Biker Biggles
Biker Biggles's Avatar
Mine gets very rough at gear changing when the oil needs doing,and if the chain is out of adjustment.
Old 04-01-07, 04:15 PM   #7
Grinch
OK, its still acting all odd. Changed the oil, adjusted/greased the clutch push-rod, and clutch cable.
I know its still buggered as when I change into first it don't lock in firmly, its just, well, soft... its hard to describe.
Old 04-01-07, 04:20 PM   #8
Scoobs
Bent gear selector fork not properly engaging each gear??? Dunno?
Old 04-01-07, 04:21 PM   #9
Grinch
Its more ideas then I had... just got to figure out how to pull it apart...
Old 04-01-07, 04:23 PM   #10
Scoobs
Dunno.
HTH
Gear changing problems vardypeeps SV Talk, Tuning & Tweaking 2 02-04-09 01:05 PM
Intermittent Sticky gears when changing up netsurfer SV Talk, Tuning & Tweaking 4 02-04-07 06:54 PM
Changing down gears is like standing on a sponge... JimmyGulp Bikes - Talk & Issues 5 19-02-07 11:19 AM
Problem Changing Down Gears leegriffiths128 SV Talk, Tuning & Tweaking 5 03-04-05 11:32 AM
