03-01-07, 09:55 AM | #1 |
Service Intervals
Apologies if this has already been covered.
Bought my SV650S secondhand with 6K miles on the clock, I had it serviced at 7,500 miles, I have now done 10,500 miles, when should I have my next service , and are there any specifics that need to be looked at ? Cheers |
03-01-07, 10:26 AM | #2 |
IIRC, the service shedule (for distance) is approx every 3500 miles. So that means you're due for a service about now.
The 7500 is the first 'major' service, and I could be wrong, but the 11k service is pretty minimal. I need to get my 11k service done actually, she's starting to feel a little rough around the edges & in need of some TLC. |
03-01-07, 11:16 AM | #3 | |
03-01-07, 11:19 AM | #4 | |
03-01-07, 12:26 PM | #5 |
11k service is basically just an inspection of hoses, cables, fastners etc, an air & oil filter replacement, and oil change.
15k service is the big one, with valve clearance check Pete |
03-01-07, 12:29 PM | #6 |
A 4000 mile sservice schedule is more than adequate.
03-01-07, 07:45 PM | #7 |
3500-4000 miles = minor service - oil change, filter, check fasteners, clean, lube & adjust clutch & throttle cables, clean & lube lever pivots, brake pins, shift linkage, chain etc.
7500= intermediate service - minor service + carb.throttle body sync, air filter, plugs 15,000 = major service = intermetiate service + minor service + valve inspection |
Service intervals. | creamerybutter | SV Talk, Tuning & Tweaking | 17 | 14-10-14 01:07 PM |
Service intervals | MCN_LiamM | SV Talk, Tuning & Tweaking | 11 | 08-05-09 12:44 PM |
Service intervals | cookystheone1 | SV Talk, Tuning & Tweaking | 18 | 25-03-08 10:12 PM |
service intervals | tiggersv | SV Talk, Tuning & Tweaking | 1 | 26-03-06 01:38 PM |
service intervals | silent | SV Talk, Tuning & Tweaking | 3 | 07-06-05 08:43 PM |
