Old 04-01-07, 11:42 AM   #1
hovis
Default tight screw
i cant undo the screw holding by bar ends on as the idiot who put them on must have used a torque wrench (it wasnt me) any hints?
Old 04-01-07, 11:49 AM   #2
Beenz
Use plenty of penetrating oil between the bolt and the bar end if its seized there. Stuff called 'Plus Gas' used to be very good as is 3in1 in a small tin. Leave it overnight then reapply in the morning. Have another go at removing the bolt tomorrow afternoon.
If its seized inside the bar it might be worth trying an impact driver of its really stuck with the correct bit. Read the instructions before using though or you could end up tightening it more.
Good luck.
Old 04-01-07, 11:51 AM   #3
Scoobs
Try giving it a sharp tap with a hammer. I can't remember if it is a philips head bolt or a allen key bolt. Stick the screw driver or allen key in the hole and give it a sharp whack as if you are trying to hammer the bar end into the handle bar.
Old 04-01-07, 11:52 AM   #4
Scoobs
Or use Beenz's advice.
Old 04-01-07, 11:53 AM   #5
hovis
waiting for a freind to finihsh work as i think he has an impact driver
when you say penetrating oil is WD40 ok?
its a phillips.............. at the mo trying not to round it
i think an allen key would be better so you could get some leverage on it
Old 04-01-07, 11:55 AM   #6
Scoobs
Better than nothing, but a proper penetrating oil like plus gas is better.
edit: apparently WD40 is a penetrating oil see here
Old 04-01-07, 11:58 AM   #7
hovis
of to DIY shop
what about a little heat from a blow torch?
Old 04-01-07, 12:09 PM   #8
hovis
mr DIY has never heard of plus gas
Old 04-01-07, 12:27 PM   #9
hovis
done
thjanx for the tips................which all helped,but i think that twisting the bar ends with mole grips freed somthing?
although the screw heads are screwad
ill be back in 10 mins with my next prob
Old 04-01-07, 12:38 PM   #10
Dan
PlusGas isn't really a DIY shop sort of thing - your local motor factors may be able to help.
Very tight fit boots sv650sfan Boots 3 22-05-08 12:54 PM
Are they supposed to be so tight!? imaleon Bikes - Talk & Issues 1 03-05-08 03:25 PM
Rear Axle bolt -how tight is tight MavUK SV Talk, Tuning & Tweaking 4 02-03-08 11:47 PM
how tight should leathers be hovis Bikes - Talk & Issues 50 06-10-06 09:20 PM
Bus in a tight squeese TSM Idle Banter 2 13-03-06 05:20 PM
