Old 07-01-07, 10:35 PM   #1
hovis
Default sky tv problem?
since getting the tinternet i have cancelled sky tv & making do with the free chanels. but now im getting a "no satellite signal is being recived" message.
as i have not got an Ariel i cant watch tv. have i been totaly cut off? the weather is not to bad so i dont think its that. & im thinking i cant phone sky.
Old 07-01-07, 10:50 PM   #2
Stig
Try unplugging the power to the sky box and then putting it back in again. Mine does this sometimes and the only way to clear it is to disrupt the power supply.
Old 07-01-07, 10:51 PM   #3
hovis
tried that 4 times
Old 07-01-07, 10:53 PM   #4
Stig
tried that 4 times
You sure you actually disconnected the power. Not just switched it off?
Old 07-01-07, 10:57 PM   #5
hovis
i pulled the plug out for a few minuites
Old 07-01-07, 11:01 PM   #6
Stig
Well the only other thing I can think of is either the cable to the dish has come loose / damaged or the dish has moved and is no longer pointing in the right direction. It only has to be a degree or two out to completely loose the signal.
Old 07-01-07, 11:03 PM   #7
hovis
hoping it fixes it self through the night.......
Old 07-01-07, 11:04 PM   #8
ArtyLady
happened to us, turn it all off, take the card out and wipe it, put it back in, turn it all on again and ours worked. HTH
Old 07-01-07, 11:31 PM   #9
netsurfer
That message appears when there is no signal (funny enough)
Cancelling your subscription wouldn't cause this to happen.
Check the coax at the back of the STB hasnt been pulled out of the plug (the plug screws on, it isnt a tight fit and sometimes can pull out)
Failing this, you have either got a faulty LNB, your dish has got a knock and been knocked off the satellite, the tuner is faulty in the STB (By any chance is it an Amstrad?) or you have water in your coax.
(Or some joker has cut your coax)
Pete
Old 07-01-07, 11:40 PM   #10
hovis
not amstrad
cant be cut as its too high
i will investigate tomorrow
thanx all
There seems to be a problem... gettin2dizzy Idle Banter 10 28-04-08 10:51 PM
i have a problem... maff Bodywork 15 29-05-07 07:22 PM
I need your help with this problem! 1-3-2-4 SV Talk, Tuning & Tweaking 6 25-09-06 01:45 PM
Battery problem / Alternator problem? localhost SV Talk, Tuning & Tweaking 4 07-07-06 09:32 AM
