Old 21-01-07, 04:46 PM   #1
hovis
Default sprocket sizes?
i have got 15 front & 44 rear........is this the standard set up ?
been reading a lot of posts & it seems that dropping the front to 14 is the way foward, but what about the back?
if you do this you lose 10 mph topend? do you miss this?
Old 21-01-07, 08:07 PM   #2
BILLY
15-44 is standard for the Curvey S 15-45 is standard for the Curvey N Going down 1 tooth on the front will turn your bike into a wheelie machine go on go for it you know you want to
Old 21-01-07, 08:38 PM   #3
hovis
will do
Old 21-01-07, 08:46 PM   #4
dirtydog
Knob faced knobster
dirtydog's Avatar
What effect does that have on the chain (the sprocket not the wheelies )
2011 Speed Triple 1050
Old 21-01-07, 08:58 PM   #5
BILLY
In theory it will cause your chain to wear out earlier but if you are using ally sprockets they will wear out at the same time!
Old 21-01-07, 09:15 PM   #6
dirtydog
Knob faced knobster
dirtydog's Avatar
In theory eh? so you're not tooo sure about that then?
I usually run with steel front sprocket and a renthal rear
Old 21-01-07, 09:17 PM   #7
BILLY
That's what I'm running! if you look after your chain it will out last the ally sprocket
Old 21-01-07, 09:22 PM   #8
dirtydog
Knob faced knobster
dirtydog's Avatar
mental note to self: top up scottoiler
Old 21-01-07, 09:27 PM   #9
BILLY
Don't forget to clean it regularly as well (the chain)
Old 21-01-07, 09:31 PM   #10
hovis
mental note to self: FIT scottoiler
Is there a way to work out the prospective top speed after increasing/decreasing sprocket sizes? monkey Bikes - Talk & Issues 15 05-04-08 12:30 PM
Tyre Sizes polishmart Tyres 4 11-03-07 03:51 AM
Sprocket Sizes Sideshow#36 SV Talk, Tuning & Tweaking 7 11-12-06 12:28 PM
sprocket sizes antony SV Talk, Tuning & Tweaking 15 07-07-06 11:49 AM
04 650S chain and sprocket sizes Captain Nemo SV Talk, Tuning & Tweaking 1 28-02-06 09:58 AM
