Old 22-01-07, 12:03 PM   #1
Luckypants
Luckypants's Avatar
Default Shorter Dog Bones - raising the rear
Can someone who has fitted shorter dogbones comment on this?
The problem I have is that my side stand grounds out on left handers. This is due to the extra exhaust pipe from my twin rene exhaust that runs under the chain and stops the stand going up as far as it should. I think that I need to raise the ride height to stop the stand grounding. (Do a lot of two up also)
So my question is, how does raising the rear ride height affect the bike. I know that it will 'quicken' the steering, but by how much? Does this make the bike flighty or more prone to tank slappers? How does this affect braking? etc. I have recently read on the ride lowering thread that fitting longer dogbones has a detrimental effect, is the same true for shorter dogbones?
Old 22-01-07, 12:07 PM   #2
Razor
I have the rear raised by about 2".
To me it makes the bike far more flickable and less lazy then it felt stock. Braking seems unaffected but I have emulators in the forks so dive is lessened.
I would have thought, just looking at my own set up, that the chain will touch the link pipe for the Left Rene if you raised the rear?
It's the reason I never went for the can-per-side look
Old 22-01-07, 12:16 PM   #3
I've got mine pretty high too, and low at the front as well, but I wouldn't run it as it is with stock suspension- the rear's not up to it. Still, you can go up a bit at the rear without real worries.
Old 22-01-07, 12:18 PM   #4
Luckypants
Luckypants's Avatar
Hmmmm Never thought of that! You could be right, as the chain runs close to link pipe when the bike is unloaded.
Was looking at these link which will raise the seat by 20mm, so raise the ride height at the stand by similar amount. Gonna have to go measure the chain / link pipe gap!
Old 22-01-07, 12:18 PM   #5
Razor
The only time mine gets it's wiggle on is when I'm sorta 100MPH+
Private roads and all that good stuff.
Old 22-01-07, 12:21 PM   #6
Luckypants
Luckypants's Avatar
ZX10R shock on way to cope with being over 12st (plus pillion) and will also do new springs / oil in forks.
ZX10R shock is slightly shorter than stock, so will mitigate the dogbones slightly.
Old 22-01-07, 12:23 PM   #7
Bear
How easy is it to fit dog bones? Bear in mind that I'm a numpty of the highest order... Will it make my bike fit me better (I'm 6'5")?
Old 22-01-07, 12:27 PM   #8
Razor
I used front paddock stand and axle stands under the footrest to get into the linkage. Steel pipe on the gorilla bar to slacken off before putting on the stands. The other way is hoist the rear with some skyhooks.
Old 22-01-07, 12:31 PM   #9
Viney
The answer is no. It does not the move the footpeg/seat any further apart. It will only make the back of the bike higher than standard.
Fitting is easy if you have one of those abba type stands. I done mine using a large step ladder and some rope...not recomended i can tell ya!!
I raised the rear on my bike with std suspension and it made a slight improvement. Jumping from my girlfirends bike to mine, the difference in 90% of all these mods is negligable. It will stop the stand grounding though and the chain shouldn't tap the left hand pipe...well as long as the chain is adjusted properly.
Old 22-01-07, 12:59 PM   #10
Grinch
Tried to sort mine this weekend... bloody nut wouldn't come off... will have to wait till next week now.
Raising dog bones and SRAD side stand svrash For Sale - SV's and SV related items 6 30-06-08 01:31 PM
Shorter dog bones, dropped yokes combo lloyd_christmas SV Talk, Tuning & Tweaking 15 13-04-08 09:25 AM
140mm dogbones - 6mm shorter than stock - raises the rear end by 0.5 - 1 inch Stu For Sale - SV's and SV related items 6 11-06-07 10:32 AM
Shorter dogbones to raise curvy rear end andyb SV Talk, Tuning & Tweaking 12 08-12-06 02:10 PM
Shorter Dog bones, rearsets or jack up plates? Tim in Belgium SV Talk, Tuning & Tweaking 15 07-08-06 11:55 AM
