Old 07-02-07, 11:54 AM   #1
SoulKiss
SoulKiss's Avatar
Default Wanted Section.......
Is it actually worth posting in Stuff Wanted for Rear Brake and Gear levers?
I cant really think of any reason for giving away/selling cheap either of these things.
There are no pattern parts for these, so replacing them IS expensive, so I would keep any spares I had - only situation I can see is if someone fitted rearsets which didn't take the standard levers and so they were no use at all.
Just my thoughts as I look forwards to paying dealer price for my Gear Lever
David
Old 07-02-07, 11:56 AM   #2
Razor
Ebay is the best bet for these bits, Even then most of the brake levers I've bought have been chipped, scraped bits of rubbish.
Old 07-02-07, 01:12 PM   #3
rictus01
rictus01's Avatar
the old "bolt for a toepeg" trick is a common one even if only to use until you get another, or keep as a share, having done a fair few now (40 or so) I've refined it to a length of 10mm studding in a rubber sleeve, much stronger than original, seems to work well and costs pennies.
Old 07-02-07, 01:19 PM   #4
fat_brstd
when i get my write off back from the garage ill be breaking it and i should have those parts for sale if you want, otherwise id say ebay but its always worth putting something out about them.
Old 07-02-07, 01:21 PM   #5
Paws
Default Re: Wanted Section.......
David
Maybe its because ive tried ebay and i cant find a rear brake lever so i thought id ask on here as some people are breaking sv's..
Old 07-02-07, 01:25 PM   #6
SoulKiss
SoulKiss's Avatar
Wasn't aimed at anyone in particular - just seemed that being in that position and seeing the number of requests I was kind of hinting that its unlikely that these parts will turn up.
Planning on bolt-fixing my gear lever once its off, but going down the dealer route initially
David
Old 07-02-07, 01:44 PM   #7
Paws
Hun you never know, if ya dont ask you dont get
Old 07-02-07, 03:48 PM   #8
You might have someone who's fitted rearsets, or is breaking the bike... Or like me, I accidentally ended up with 4 spare gear levers at one point
The bolt-and-lever trick's a good'un, I've been running around for about 15000 miles on my current one, but nobody'd notice unless I pointed it out. (M8 bolt, with the original rubber around it, looks like new- it's been broken twice so it's a bit short though )
Wanted: 160 section part-worn(s) Spikenipple Stuff Wanted 5 07-09-08 05:04 PM
