Old 12-02-07, 03:37 PM   #1
Baph
Default Joining the bike video masses
As the title, I've decided to join the "bikers who shoot video" crowd.
I've had a bit of a poke around, and for what I'll use it for (sunshine bimbles around the welsh countryside), most systems seem pretty damn expensive IMO.
My priorities are to get a reasonable video (I don't mind a little pixilation), at a reasonable frame rate (17fps+), and a reasonable amount of storage. I'm also looking to spend as little as possible at the moment. If I use it a fair amount, I'll fork out more and quite possibly, stick a few cameras on the bike, but not right now.
I have ordered a 3MP digital camera to play with, because I found it dirt cheap, and I can make my own mount for it etc. This ticks all the boxes as far as I can see, 19fps, takes SD cards. It's also cheap enough that if it doesn't work, I can see it on & probably make a profit!
Does anyone have any advice/pointers on the subject as a whole? Bare in mind though, that I want to spend as little as possible & I'm more than prepared to hack a solution.
Shooting video on the AR could be interesting
Old 12-02-07, 03:44 PM   #2
ive got an old JVC camcorder which i sit on a sponge and tape to my tank works tho
Old 12-02-07, 03:51 PM   #3
Baph
I don't like the idea of tape on paint. Might not damage anything, but I'd rather not risk it personally. I'd rather super tight bungee a base (polystyrene or otherwise) to the bike, and gaffer tape the camera to the base.
Old 12-02-07, 05:15 PM   #4
trickywoos
*Information shamelessly nicked from Sv Thou Site*
If you've seen the videos of the Coast Road, and the Andorra road that were put on here over the past couple of days (U really should btw!), these were filmed using an old Panasonic NVGS75. The mount came from www.tailtidy.com for about £30.
The Video quality isn't great as it had to be reduced to fit the size limitations of google video.
Hope that helps!
Old 12-02-07, 07:41 PM   #5
i used electrical tape lots of it and the sponge was to try and reduce vibrations.
Old 12-02-07, 07:58 PM   #6
socommk23
GET A HELMET CAM!
Old 13-02-07, 12:31 AM   #7
Baph
Default Re: Joining the bike video masses
Originally Posted by socommk23
GET A HELMET CAM!
Hmm.
I've seen a few helmet cams, and they aint that cheap!
Keep all the advice coming though folks, and I'll be checking out the above link, err, now
Thanks all (even socommk23! :P)
Old 13-02-07, 11:15 AM   #8
socommk23
blue has some footage of his minimoto antics from one. the quality seems to be ok.
price wise....ask him.
Old 13-02-07, 11:47 AM   #9
Luckypants
Luckypants's Avatar
Mate has a 'bullet cam' that he uses for MTB. Small DV camera goes in his bum-bag and bullet lens thingy goes on his helmet. Can be shaky and slow to react to changes in lighting. BUT this setup could go on the bike, camera under seat / tank bag / tail pack, bullet cam mounted on fairing / mirror / indicator. Jelster posted a link to some vidoe he shot using a bullet cam mounted on his fairing somehwere, cannot find the link right now though.
When bike back in one piece will borrow mate's setup for 'trials'
Luckypants is online now   Reply With Quote
Old 13-02-07, 11:51 AM   #10
Blue_SV650S
I use ATC1000 on my trackbike, its an all-in-one setup ~£130
ATC1000 Example ATC footage
Minimoto mate uses a remote 'bullet cam' ... remember this is low light conditions too ... Example bullet footage
The ATC is ok, but the quality is far superior on a bullet cam ... if you have a camera already (with AV in) then go for remote bullet cam its will cost about the same as the ATC just for the bullet ... if like me you don't then the ATC it is
Fun Bike Video of Ed TheNinj1 Idle Banter 26 16-04-09 08:38 AM
Jamie (Bear to the masses) has found the right bike for him... Stig Idle Banter 7 18-11-07 06:15 PM
Bike video gettin2dizzy Bikes - Talk & Issues 21 02-09-07 11:05 PM
