Old 21-02-07, 04:56 PM   #1
Law
Exclamation Can't drill into exhaust pipe
Ok, my attempts at drilling a hole into my pipe has failed. I have a week to fit my exhaust before it goes in for it's service.
How can I drill a 3/16" hole?
Do I just need a more powerful drill?
Old 21-02-07, 05:04 PM   #2
hovis
Default Re: Can't drill into exhaust pipe
is it a cheap cordless drill? although it should do
what is the drill bit like?.......probaly this is the prob?
Old 21-02-07, 05:05 PM   #3
fizzwheel
fizzwheel's Avatar
Have you got the right sort of drill bit for the material you are trying to drill into ?
Why are you drilling a hole in your exhaust to fit it anyway ?
Old 21-02-07, 05:21 PM   #4
Law
It's a cordless drill and the drill bit just spins across the surface of the pipe. What drill bit should i be using? I might leave it to be done at the service.
I'm drilling a hole cos according to my instructions I need a hole in the pipe for a securing rivet to go in which is then clamped over with the exhaust clamp.
Old 21-02-07, 05:27 PM   #5
hovis
a metal drill bit
stone has a bit welded into the end
piccy to follow
put a piece of maskin tape over where you want to drill to stop it slipping
Old 21-02-07, 05:30 PM   #6
rictus01
rictus01's Avatar
For a start some basics, you're drilling a curved surface aren't you? either centre punch or use some gaffer tape(make a cross) to make a start point, lubricate,start slow, use a colbalt drill bit.
If you still have no joy you don't have the right tools for the job.
Old 21-02-07, 05:30 PM   #7
fizzwheel
fizzwheel's Avatar
If its spinning across the surface, it sounds like you've got the wrong drill bit.
You want a bit designed for Metal, preferably a HSS "Hardened Speed Steel" Drill bit. ( I think ) Also if your bit is blunt thats not going to help either.
Old 21-02-07, 05:33 PM   #8
hovis
Originally Posted by hovi5 View Post
a metal drill bit
piccy to follow
Old 21-02-07, 05:37 PM   #9
Law
Thanks everyone
It looks like I have a (slightly blunt) metal bit, will try again tomorrow with some gaffer tape (maybe go out & get a new bit) and let you know how I get on.
Old 21-02-07, 05:58 PM   #10
oldjack
You need a HSS "high speed steel" drill bit, its capable of running red hot without getting blunt, whereas a normal carbon steel bit will soften easily from the friction generated. If its a stainess steel pipe it will be harder to drill anyway because the steel "work hardens" as you are cutting it. Try a centre punch and a new HSS bit with a blob of oil on the centre punched start point to act as lubricant.
Jack Brown, BSc (Hons) Industrial Metallurgy !
Cut exhaust pipe adoh30 Bikes - Talk & Issues 10 12-08-08 06:46 PM
exhaust pipe 01 sv650s SV Talk, Tuning & Tweaking 7 26-11-06 12:42 AM
exhaust pipe oldie SV Talk, Tuning & Tweaking 0 30-08-06 08:58 PM
exhaust pipe oldie Stuff Wanted 0 29-08-06 02:35 PM
SV650S - Exhaust pipe Stupidbash SV Talk, Tuning & Tweaking 3 27-01-05 07:48 PM
