Ancillaries Post your own reviews, opinions and experiences on various other bits and bobs, such as rearsets, oil, engine bits.
Old 02-03-07, 02:24 AM   #1
clm2112
Default Motrax Flash-It solid state relay
Hi y'all,
Just wanted to post my experience with Motrax "Flash-it" solid state turn signal relays. http://www.motrax.co.uk
I recently replaced all the turn signals on my K6 with LED lamps. I got a blink rate that was darn near an epileptic fit inducing strobe. I tried ballasting down the turn signal circuit and got a fast blink. I didn't care for the idea of installing 20watts worth of ballast resistors in the circuit, so I started looking for a 12volt solid state relay.
Ended up using the "Flash-it" and I'm quite pleased with the results. The blink rate is back to normal without the use of any ballast resistors in the circuit.
They don't make a Suzuki specific relay (with the combined flash relay/sidestand relay/diodes) but installing the universal fit one was pretty easy. I removed terminals F (light blue) and G (brown) from the relay socket on the bike, then soldered the SSR directly to the wires. Black wire from the SSR to the light blue wire in the harness, red wire on the SSR to the brown wire in the harness.
Piece of cake. Normal blink rates, minimal load on the electrical system.
Old 12-03-07, 12:22 PM   #2
ivantate
Default Re: Motrax Flash-It solid state relay
Excellent. I think I may go and get one of these this afternoon as I cant seem to get my indicators to slow down.
Old 16-03-07, 07:14 PM   #3
phil24_7
Where are these wire???
I'm gonna be going led very soon but don't know the best way to slow down the blink rate, or for that matter, where to make any connections!
Plase help.
P.S. Where do the universal relays wire in?
Old 03-04-07, 01:07 PM   #4
sieade245
The original relay unit is sat next to the fuse panel on the rear tray. It has 7 wires going into it. You can remove individual connectors from the terminal block using a thin instrument such as a tweezer leg. The wires from the motrax relay are thick and will slot straight into these connectors and provide a tight fit. You could possibly get away with not soldering (I didn't bother). Just be sure to use insulation tape on the connectors when you're finished so they don't short.
Hope this helps, Si
Old 08-05-07, 07:37 PM   #5
ivantate
Have finally got around to fitting this and it works perfectly. No wiring instructions in the box so these were very handy.
I have pushed the wires into the terminal on the wire and soldered them. If I ever need to reverse the operation I should be able to do it.
Old 09-05-07, 06:53 PM   #6
Raiden
Just to add, I've just done this on a curvy SV. The wiring was different colours than described here. I pushed out the two wires from the multi relay socket. Light blue which goes onto the Black of the new relay and the other was Orange with a green stripe, this goes to the red on the relay.
For reference I picked up one of the relays you can find in Halfords on their limited bike shelf. I just removed the connectors from the Kawasaki connector terminal. The Suzuki ones pushed in nicely and the I just tapped them up afterwards.
Job done
Old 05-06-07, 11:04 PM   #7
southy1978
Hi, would this relay work with mine as i have the standard front indi's and led rear indi's?
Old 10-06-07, 11:06 AM   #8
clm2112
Yes, it will work for yours as well. The whole point of using a solid state flasher module is that it does not need a specific load on it to control the flash rate...it works with any combination of regular and LED bulbs. I've got eight turn signal bulbs at this point. Front and rear are LED, two in the instrument panel, with an extra pair of amber regular bulbs in place of the front marker lamps next to the headlights. (The flush mounted LED front turn signals were not very visible from the front of the bike, hence the extra pair.)
Old 22-06-07, 10:09 AM   #9
embee
embee's Avatar
Just be aware that the fast blink rate is intentional, it shows when a bulb has failed. All relays could be made without that if it was so desired.
The idea is that LED's will last as long as the vehicle, so you don't need to alert for failures.
Using a fixed rate relay with bulbs could mean you won't notice a failed bulb.
Just be aware................
Old 12-04-08, 10:52 PM   #10
Biker Biker
Originally Posted by clm2112 View Post
Hi y'all,
Bingo!
Thanks
Motrax relay - no flash. Miles SV Talk, Tuning & Tweaking 4 25-02-09 12:25 PM
FLASH FLASH...Q for the police people maff Idle Banter 16 04-10-08 07:03 PM
State of the Uni, Union State, whatever you wanna call it! Anonymous Idle Banter 0 03-04-06 04:40 PM
SV in a right state! aimhamilton SV Talk, Tuning & Tweaking 12 18-01-06 03:49 PM
Traffic Light Cameras ..Flash Flash ? Eggspit Bikes - Talk & Issues 28 23-11-05 11:02 PM
