Old 02-03-07, 04:51 PM   #1
tomjones2
Default Possible Dead Battery?
My sv has been stood for 6 months as i was away but I had orgainsed for it to be started and run for 5 minutes every month to keep the battery going. After 2 months there was not enough power to even keep the lights going.
After I returned i have atttemped to bump start it, walked up the hill 3 times and it still didnt start and then moved on to jump starting of my z750
The bike starts fine but as soon as you disconnect it from the z's battery the sv dies instantley. Tried this 3 times on the last time the bike was running for a good 30 seconds at 5k and it still died as soon as it was diconnected
I am right in saying that the battery is so weak that it can't even provied enough charge to keep the FI system going? Is thier any solution apart from a new battery.
Thankyou
Old 02-03-07, 04:54 PM   #2
jambo
jambo's Avatar
Default Re: Possible Dead Battery?
5 minutes running will not add the charge that starting the bike took out. First of all charge the battery up properly on an optimate or similar. It's possible the battery's dead but try the usual tests for voltage accross the battery when running and not running to see if the reg/rec and other electrics are ok.
Edit: Try this thread http://forums.sv650.org/showthread.p...t=test+battery
Old 02-03-07, 04:56 PM   #3
hovis
where abouts are you? sounds welsh to me? as you might be able to borrow an optimate?
i have one
Old 02-03-07, 05:10 PM   #4
tomjones2
Cheers for the offer but i'm in near banbury (oxford way)
dead battery. metalangel SV Talk, Tuning & Tweaking 4 12-03-09 02:57 PM
Dead Battery DF! SV Talk, Tuning & Tweaking 2 01-09-08 05:36 PM
Dead Battery After Hol Staffz Bikes - Talk & Issues 3 27-07-08 06:36 PM
dead battery MGYoung SV Talk, Tuning & Tweaking 1 17-05-06 01:19 PM
Just a dead battery? Natasha SV Talk, Tuning & Tweaking 16 22-08-05 02:05 PM
