Old 03-03-07, 01:28 PM   #1
gixxxerfreak
Default Help needed with restricted sv
Hi,
I own a sv 650 carb version & it's restricted. I want to derestrict it but there are no washers under the carbs & the sliders are also without a hole. Is there any other way that dealers used to restrict a sv? Ignitor maybe?
Help me!!!
Old 03-03-07, 01:48 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: Help needed with restricted sv!!!
If there are no washers then it will be the sliders, you can only see the hole if you take the sliders out of the carbs.
http://forums.sv650.org/showthread.php?t=62081
Old 03-03-07, 01:48 PM   #3
rictus01
rictus01's Avatar
I've not seen any other way of restricting a curvy,are you sure it's not between the head and the rubber boot ?
After that I'd guess at either the carbs themselves or exhaust, I'm not aware of any restricted ignition units for this model.
Cheers Mark.
Old 03-03-07, 02:04 PM   #4
gixxxerfreak
I took the sliders out & there are no holes in them (except the 3mm hole in the bottom). I suppose the washer you mentioned would narrow the intake but there is no such thing & the intake hole is the same size all the way to the valves.
Old 03-03-07, 06:08 PM   #5
M1TCH
SV650.ORG FAQ's and How To's.......
Can they tell it's not restricted? GeneticBubble Bikes - Talk & Issues 214 25-03-09 12:45 PM
K8 restricted ecu Whitehouse SV Talk, Tuning & Tweaking 2 21-01-09 12:20 PM
ECU - SK3 (Non Restricted) bobit69 Stuff Wanted 0 29-05-07 09:54 AM
where to buy a restricted ECU? hangalldjs SV Talk, Tuning & Tweaking 7 19-01-07 01:07 PM
Restricted her, restricted there. graeme1841 SV Talk, Tuning & Tweaking 6 10-07-05 01:09 PM
