Old 06-03-07, 06:17 PM   #1
svryanpompy
Question ignition advancer
i been looking at a factory ignition advancer what is about £45
what improves throttle response & maximise the bike torgue.
just wondering if any one brought this kit or one like it
and were they got it from & how much
thanks
Old 06-03-07, 06:27 PM   #2
BILLY
Default Re: ignition advancer
Save your self some money and do the wire mod under the tank See here http://forums.sv650.org/showthread.p...=Timing+retard
Old 06-03-07, 06:44 PM   #3
svryanpompy
dose this work?
is the bike a lot more response a round coners and that
Old 06-03-07, 06:56 PM   #4
svryanpompy
Question Re: ignition advancer
just read about cuting the ignition wires under the tank for more power out of 3rd & 4th
dose any one know it works
people saying that dont get up 70 if you do it
thanks
Old 06-03-07, 08:52 PM   #5
Ignition advancer and TRE are 2 different things... I quite like the ignition advancer mod with a stock engine, it's got a nice effect on drivability. It's not quite easy to do, but it's DIYable if you've got a bit of experience. And it's quite cheap
Old 06-03-07, 09:42 PM   #6
BILLY
Originally Posted by svryanpompy View Post
dose this work?
Yes it works but the SV is responsive as standard anyway!
Old 06-03-07, 10:31 PM   #7
21QUEST
21QUEST's Avatar
I agree. me, I just twist the loud handle a bit more
Ben
Nemo me impune lacessit.
Old 07-03-07, 10:19 AM   #8
r4ce_e3nd
I have one key laying around here, if you are interested, contact me
cheers
Old 07-03-07, 10:38 AM   #9
adam_castell
using the ignition advancer key in conjunction with higher octain fuel will give you a healthy increase in tourque across the whole rev range, more so at the bottom end, this is a simple way of making use of the extra octain fuel.
the wire cutting mod will advance the ignition and slighty increase tourque in sencond and third gear to match the other gears.
the reason its only second and third gear is due to curent regulations for sound levels, the sound test manufactures have to pass is driving the bike past a microphone at full wack in second and third gear, so mr suzuki simply retarded the ignition in second and third to pass the test, its the same case with most bikes.
none of the above mods will give massive power increases, theres a good chance youll hardly notice them, but i say every little counts
Old 07-03-07, 11:08 AM   #10
sinbad
So has anybody done a test on a dyno to see how much more power there is in 4th gear compared with 3rd/2nd?
Ignition advancer wanted boo86 SV Talk, Tuning & Tweaking 22 05-09-08 11:58 AM
ignition advancer svryanpompy SV Talk, Tuning & Tweaking 3 18-03-07 12:15 AM
ignition advancer svryanpompy SV Talk, Tuning & Tweaking 6 07-03-07 10:59 PM
Ignition advancer? sixstring SV Talk, Tuning & Tweaking 19 22-07-06 06:39 PM
Ignition advancer?????? bobbydee SV Talk, Tuning & Tweaking 10 16-03-05 06:04 PM
