Old 08-03-07, 09:46 AM   #1
John 675
Post Wheel alighnment
here is a very quick quiery for the wealth of info,
my wheels are out of alighnment when i ride ( im buying a new set of yokes from kwak ZZR at the weekend hopefully ) which will correct them because since my prang when the bars are straight the wheel is slightly to the left. once replaced will this resolve some of me only getting 120Mph out of her on track days?? also scotoilers??? worth the Moolahh?? (££)
cheers
Jon
Old 08-03-07, 10:40 AM   #2
rictus01
rictus01's Avatar
Default Re: Wheel alighnment
Wheel alignment, well as long as the replacement yokes are straight and that's the only problem then yes, but I'd suspect the bars are bent a bit &/or the bar mounts, also the wheel spindle, but regardless get it checked!!!!!!!!!!!
Scottoiler = yes.
Cheers Mark.
Old 08-03-07, 10:54 AM   #3
John 675
Post Re: Wheel alighnment
Scottoiler = yes.
Cheers Mark.
ive had everything but the yokes reoplaced on my fron end except the wheel also, so forks and everything are new,
i need a damm good service, but if me wheel is out of alighnment ill fail my mot i presume?? but theyl soon be sorted, i guess i should look at my chain tension as well, i even changed the bars and master cylinder.
Old 08-03-07, 12:20 PM   #4
John 675
woo hoo its service time ! ! ! next week my bike should be reborn to former glory ! ! ! ( i hope )
Old 08-03-07, 01:11 PM   #5
SVbiker
Please let me know what was wrong as I happen to have the same problem here.
Old 08-03-07, 01:32 PM   #6
zunkus
Welcome to the madhouse SVbiker!
Old 08-03-07, 01:36 PM   #7
John 675
been joined for a year by the looks of it lol, i will keep you updated
Old 08-03-07, 02:14 PM   #8
zunkus
Sorry lylej but I was refering to SVbiker
He's my little brother!
Old 08-03-07, 03:25 PM   #9
lylej i'd check the spindle if you havent had a new one, i had a prang which was no where near your 70mph kerb job but my spindle was bent a friendly sv650.org member helped me out there tho.
Old 08-03-07, 03:33 PM   #10
John 675
i changed it to be on the safe side, it didnt look bent but i didnt want to risk it
there quite expensive though arnt they!!!
SV650 Front Wheel - Do any other Suzuki models use the same front wheel? williamturner1 SV Talk, Tuning & Tweaking 11 30-05-10 02:31 PM
wheel spin thing (for rotating wheel) Corf SV Talk, Tuning & Tweaking 19 19-01-09 10:41 AM
T-Wheel tactcom7 Idle Banter 1 31-01-08 07:00 PM
wheel antony SV Talk, Tuning & Tweaking 3 12-02-07 05:05 PM
front wheel maintenance ?? need to prop up front wheel etc valleyboy SV Talk, Tuning & Tweaking 2 26-08-05 07:50 PM
