Old 14-03-07, 09:43 AM   #1
sparkymarky
Angry Hazards won't turn off/Meta Alarm
Went to start the bike up this morning - de-activated the Meta 357T alarm and went to start it which it did after a couple of attempts but then the Hazard lights started flashing and wouldn't turn off.
Tried switching engine off, activating, de-activating alarm, pressing hazards button on/off - all to no avail.
Had to leave it in garage with Hazards blazing so will probably have a flat battery when I get home!
Anyone had similar problems or clues as to the cause?
Didn't have time this morning to get the seat off and check connections etc, so hoping it's just a loose cable or something?!
Old 14-03-07, 12:46 PM   #2
keithd
Default Re: Hazards won't turn off/Meta Alarm
i had the same problem over christmas. for the life of me i cant remember what i did to stop it.
i'm think it was a combination of switching the alarm off, putting keys in ignition cancelling the indicators, re-arming the alarm again...something like that. sorry to be vague, but i know it took a bit of trial and error. its not happened to me before or sice.
Old 14-03-07, 01:11 PM   #3
sparkymarky
Unhappy Re: Hazards won't turn off/Meta Alarm
Thanks for that - good to know that at least I'm not the only one to have the problem! I will try all the things you mentioned when I get home.
Bit of a bad time for it to happen as it's booked in for it's MOT on Sat!
Old 14-03-07, 04:48 PM   #4
Luckypants
Luckypants's Avatar
I got one of them. If all else fails, disconnect the battery overnight, this will reset the alarm to factory settings and problem should go away.
Never had a problem with the alarm, but the above should work.
what alarm should i get datatool or meta zsv650 SV Talk, Tuning & Tweaking 24 23-09-08 10:52 PM
Meta Alarm Removal petevtwin650 Bikes - Talk & Issues 4 15-09-08 09:50 PM
Meta Alarm Technician plowsie Bikes - Talk & Issues 3 31-05-07 09:12 PM
Meta Alarm Help!!! Samurai Bikes - Talk & Issues 5 09-02-06 02:52 PM
meta alarm pagers Skullmonk3y Bikes - Talk & Issues 6 29-05-05 09:33 AM
