Old 14-03-07, 08:11 PM   #1
Duke
Default Automatic Chain Oilers
There are several types of automatic chain oliers, motorax electronic and the Scottoiler being vacuum operated.
I used to have one that had a sensor that rattled through movement of the bike and delivered the oil based on bike movement. The problem is that I can't remember the name of the unit. Has any one heard of it?
Thanks
Duke
Duke is offline   Reply With Quote
Old 14-03-07, 10:44 PM   #2
Brucey
Default Re: Automatic Chain Oilers
Sounds like a ChainTec unit got one on my SV think they went bust a Motrax Lubetronic wired to come on when you apply the brakes works very well indeed keeps the oiling about right not like the Scot oiler which is either not working or ****ing out oil very hard to ever get right IMHO.
Old 15-03-07, 09:53 AM   #3
carrickman
Hi
I have seen http://www.chainoiler.co.uk/index.html
It seems cheap and easy to fit but I have not used one yet.
Old 15-03-07, 09:56 AM   #4
Luckypants
Luckypants's Avatar
Thanks
Duke
ChainTec. HG used to do them. Mine just packed up, so going for a Scottoiler now.
Old 15-03-07, 10:01 AM   #5
scorpion
Just a quick sidestep. Brucey how did you get your display lights coloured like that on your avatar?
Old 15-03-07, 10:25 AM   #6
jambo
jambo's Avatar
Been using a scottoiler for about 18,000 miles now and I have to say I really don't find it that problematic to keep the speed right, a lot of it has to do with how it's installed, as if it's right up against the exhaust or somewhere else that will get hot it will affect the flow rate.
I'd vote scottoiler, but I've not tried the others.
Old 15-03-07, 07:37 PM   #7
Rog
Originally Posted by carrickman View Post
Hi
Ive got one of them. they look a bit Heath Robinson but they do the job very well.
They work through gravity so a quick squeeze of the oil bottle before you go out (2 sec job) and its charged and you are ready to go.
Old 15-03-07, 10:02 PM   #8
tomjones2
Had a scotoiler on three bikes and never had a problem, I run mine a little quick so it spills a little oil on the sv silver wheels but it does make the chain last well. Never had a problem with the flow rate changing, apart from changing it when the tempature changes dramatically.
Old 17-03-07, 06:50 PM   #9
Duke
Thanks for your comments.
I can't seem to find the Chain Tec unit anywhere, I probably go for the standard Scottoiler.
Has any one seen them for a good price, my local shop wants £65 plus VAT?
Duke
Old 18-03-07, 09:22 PM   #10
Luckypants
Luckypants's Avatar
Duke
ChainTec went bust I think (or stopped being imported). £65+vat is a reasonable price. £69.95 plus p&p from Scottoiler direct.
Try for £75 quid?
Chain lubrication, auto oilers. yorkie_chris Bikes - Talk & Issues 1 06-11-07 11:45 AM
New automatic music player. splund Idle Banter 3 30-10-06 01:47 PM
Clutch and throttle stiff to use - cable oilers??? huge SV Talk, Tuning & Tweaking 13 23-05-05 09:51 PM
Chain oilers Kingy SV Talk, Tuning & Tweaking 4 23-12-04 10:48 AM
