Old 19-03-07, 07:52 PM   #1
redeye-dv
Default clonking front end
When I hit a big hole, like a dropped drain cover I feel a click in the handlebars, or a small knock.
It doesn't do it on normal holes just big ones. Has anyone else noticed this or is it just my bike,
Its a 2006 650 s. I prviously had a vfr vtec which was heavier, but never had any knocking at the front.
Old 19-03-07, 07:54 PM   #2
Default Re: clonking front end
ive heard of others doing this but i personally avoid big holes in the road.
Old 19-03-07, 08:01 PM   #3
Jussi
Same here occasionally. You should see some roads we have specially after winter...
Well changer the fork springs and oil yesterday and the bearings were ok. Front felt ok. And when the fairing was removed also mounted braided brake lines. A big syringe was a big help on bleeding the brakes. I pumped the lever and my brother sucked with the syringe from the bleeding points of fron calibers went fairly easy.
Went to the garage on sunshine around 1pm left at 7pm. Meanwhile started snowing 10cm of fresh heavy snow out of the blue Winter hits back...
Old 19-03-07, 08:01 PM   #4
I'm_a_Newbie
Hi.
I have read about this on the forum before, my K3 model does it as well. I seem to remember a posting some time ago that details how you could get rid of it. It involved stripping the headstock and changing things around, what I can't remember though. As long as you can feel any clonking while braking sharply etc. then I would not worry about it. If you are unsure get a dealer to check it.
Tim
Old 19-03-07, 08:12 PM   #5
jim@55
'mechanics sarcastic tone'-:they all do that sir ,its quite common
Old 19-03-07, 08:28 PM   #6
rictus01
rictus01's Avatar
guess the search button has the day off
Old 19-03-07, 08:59 PM   #7
riktherider
majority of sv's happen to do this. cheap forks. thats it. plain and simple. not going deep into it but its to do with the dampening rods and the weight of the oil. the rods hit against the bottom of the fork or something like that. hence why anyone who has done a fork change, either s-rad forks or usd forks, no one has the problem. only real way of resolving it. if you change to better springs, like i did, it just returns after a good year after the spring looses its initial tension. mechanics not wrong though.
Old 19-03-07, 09:22 PM   #8
Moffatt666
I'm glad it's not just my bike!
Old 19-03-07, 10:18 PM   #9
BILLY
Mine still does it with the SRAD front end fitted can't work out what it is yet!! So I try to avoid pot holes to
Old 20-03-07, 08:03 AM   #10
redeye-dv
Thanks to all, excellent idea about the search button and avoiding holes in the roads, glad it's not just my bike, I will mention it next service and see what the dealer has to say.
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
SV650s 2000 model, yellow. I need front central and front right fairing. OdySV Stuff Wanted 0 25-02-07 04:47 PM
Clonking on startup Warthog Bikes - Talk & Issues 16 15-06-06 09:48 AM
