The screws that hold on the little cover plates that allow you access to the back of the mirrors are just turning any ideas on removing?its a K1 model.
These little bolts go into a rubber sleeve with a nut at one end. If the bolt has come out of the nut, it might be just held by the rubber. Try unscrewing while gently prising the cover back, if the bolts unscrew all is good. Dont force it.
will have a try, do you know the bolt size in case its a drill out job.just phoned the Suzuki dealer nut and bolt for both sides and postage £17.52!!!!!!!!!!!wow
