...the wrong way
![]() Yup folks, happened again. Numpty! Went home on the A543 over Denbigh moors last night. All was well, listening to the newly fitted Scorpion singing. Then my mind wandered ![]() Locals, if you come up from the A5, past a couple of the farm houses, there's a right hander sort of in a dip, then a couple more houses, then a left hander. It was the left hander there, but I was going the other way. Came along a straight, to a right hander (before the one I came off at). I know the SV will take this happily in 4th. I was at the bottom of 5th. Sh*t riding Dave, sort it out. Opened the throttle along the straight, coming to the bend that I know I can happily take in 3rd. Usually a whole lot of brakes too to get around it. It was at this point my mind wondered away from me. What gear am I in? Beggar, don't know. Hmm. Why is the back end shaking? Crap the rear is locked! Release back brake & apply front (I wasn't using the front brake until this point). Sh*t, have I scrubbed enough speed off to avoid that wall? Don't think so, it'll break less if I throw it on the road, so lets do that. I don't remember me hitting the floor, so I'm under the firm opinion that I hit the ground almost running. An inspection reveals that my right toe took a little grinding, but that's all. Boots did their job. Later I've found a nice big dent in my left leg, where it looks like I caught the pillion peg on the left as I swung my leg over the bike (360 dismount & run styleee). My first thought when I got to the bike, F* that's going to be expensive! I'm approx 40miles from home, can I ride it? Turns out, the crash bung took the brunt of it ![]() So I'm fine, and the bike took minimal damage. Thank crap the bungs weren't still protecting the fridge! My over-analysis of the off, tells me the following things:
![]() So, now, where to get a single bung & brake pedal for a K6? ![]() |
#3 | |
![]() As for over-analysis ![]() ![]() Now, stop been a numpty.... ![]() Ben |
Know the corner you mean. Bad luck man, but as everyone will point out, you are in one piece.
Avoiding them dry stone walls is a top idea. Take it easy, hope you not too sore today. |
Oh bum.
![]() Glad you're alright and the bike has minimal damage. |
oops, ouch
Thanks folks. As you can tell, I'm pretty light hearted about it (probably because I know why it happened).
Strangely my left arm is a little sore, no visible marks or anything. Just aching. My riding style hasn't changed that much (again, I know what happened), but I'm approaching corners a little slower. That's mainly to do with the fact that I haven't got a back brake at the moment. But other than that, all is good. Must remember that the SV doesn't have the same brakes as the R1 does. Hmm, come to think of it, could I transfer the discs, calipers & lines before my mate gets back from his holiday... |
Maybe not having your back pedal for a while might get you out of the bad habit of using your back brake.
![]() ............except for slow speed and big skids ![]() Glad you and your pride and joy are up and about. Its nice when you know what you have done. Easier to get over it quickly. Motorcycling is never mediocre! ![]() |
#9 |
glad you're ok
reading that sounds like you think about what gear you're in too much. i often have no idea what gear im in, i go by the revs and the speed and the feel if that makes sense. take it easy dude. |
#10 |
Aw bad luck Dave, sad to hear just joined my Easter crash club hehe. Glad you are alright, and amazing that your bike is still pretty much fine! I have to say, I hurt more on day 2 now, a bit more muscular aches have come up, including thumbs from the bars I guess and neck muscles like I have been headbanging too much. All still minor though, nothing serious!
gears grinding | KillaSV | SV Talk, Tuning & Tweaking | 1 | 16-03-08 07:39 PM |
grinding noise from back wheel | 650sx | Pennine Massive | 4 | 03-05-07 01:01 PM |
Grinding 1st!! | Spider | SV Talk, Tuning & Tweaking | 9 | 02-01-07 02:50 PM |
Baph down :( | Baph | Bikes - Talk & Issues | 31 | 22-11-06 09:42 AM |
Baph!! | Ping | Idle Banter | 12 | 03-10-06 10:49 AM |
