Old 15-04-07, 03:28 PM   #1
svrash
Default Making an exhaust fit?
I got my self a Micron delta+ can of an R1 but the inlet size is 5mm bigger, the internal baffle is the same size as my race can so it doesn't fall down my link pipe, i've stubbyed it by 50mm because it was longer then i wanted and now it looks sweet
My question is could i pack out the inlet with a home made gasket of cardboard and tin foil? after all thats all the exhaust gaskets on the head are made from
The reason i got the can from an R1 is because the don't make the delta+ for 99-02 SV650s and micron pipe work.......why? i don't know
Old 16-04-07, 10:26 AM   #2
Default Re: Making an exhaust fit?
I used a bit of exhaust bandage when I was bodging on exhausts... Worked a charm. My mate Ben uses tinfoil, lots and lost of tinfoil, but then he also used silicon grease to try and unstick his brakes so take that as you will.
Old 16-04-07, 08:24 PM   #3
svrash
I've made some rings with some ally 10mm bar i had lying around and with them in the inlets exactly 52mm, perfect
Old 16-04-07, 09:15 PM   #4
Born again
It may be a silly question but will fitting cans from other bikes mess with the fueling when put on an SV........
Old 16-04-07, 09:18 PM   #5
svrash
Probably the internal baffles the same and now i cut it down to the same size it should be any different to the other one....in theory
Old 17-04-07, 08:31 AM   #6
mister c
mister c's Avatar
I packed mine out with leather when it was fitted to my XJR. The can was originally for an R6, so was a lot bigger. Doing on the cheap, buy yourself a pair of rigger gloves from the DIY store & cut them up with a stanley knife.
Old 17-04-07, 06:47 PM   #7
svrash
Well its fitted, there is a bit of a gap but i'll find something to fill it and use some exhaust jointing paste to seal it completly
Sounds better then the old race can (with out the baffle)
Old 17-04-07, 08:57 PM   #8
BILLY
Old 17-04-07, 09:17 PM   #9
svrash
Originally Posted by BILLY View Post
It looks exactly the same as the old one but its road leagal and a little deeper without the baffle
Drew is making me do it.... Peachey Idle Banter 23 22-11-08 10:12 PM
Making a web page metalmonkey Idle Banter 5 23-02-08 10:42 PM
Making the exhaust go BANG!!! Bad for the engine? thor SV Talk, Tuning & Tweaking 28 05-10-07 07:07 PM
Making the sv quicker rs_tubby SV Talk, Tuning & Tweaking 18 04-06-07 10:13 AM
making a stubby exhaust silent SV Talk, Tuning & Tweaking 21 10-02-06 05:40 PM
