Old 18-04-07, 03:53 PM   #1
scorpion
Default 150mph +
Ok so we've talked about changing front sprockets from 15 to 14 teeth and rear sprockets up in teeth for better acceleration so......
Is it possible to get 150mph + out of an sv650 by putting a smaller sprocket on the rear? How many teeth do you rekon?
Old 18-04-07, 03:55 PM   #2
hovis
Default Re: 150mph +
if droping to a 14 loses 10mph putting a 16 on the front should raise 10mph lower the back 2-3 & in theory ...........maybe?
Old 18-04-07, 04:00 PM   #3
riktherider
possibly be able to make 150 by changing the sprockets....BUT pulling away from standstill wouldnt be very nice. you would have to give it a lot more revs to get going, and wont be know where near as quick as a standard sv. just get a thou. much easier
Old 18-04-07, 04:12 PM   #4
r4ce_e3nd
In theory, you can calculate it, but in practice it will be different. You lose a lot of speed caused by the wind and when your engine isn't strong enough you can propably not make it.
calculations:
a: topspeed with stock sprockets
b: topspeed with 2 teeth more (for example)
c: # teeth stock
d: # teeth stock + 2
b = a*d/c
example: a= 140MPH, c= 42 (don't know how many it has), d= 44 => b= 146MPH
Old 18-04-07, 04:16 PM   #5
gettin2dizzy
theres no chance you'll make it. It'll run out of steam, remember the power isn't made at the top of the rev range, so you'd need to hae 150mph at about 9000rpm. Its not going to happen!
Old 18-04-07, 04:18 PM   #6
Baph
You might make it, but you might have to go one up on the front & 2 down on the back (same effect as 2 up on the front).
However, if you do hit 150mph, think yourself bloody lucky you didn't run out of road first. It'll take years!
Old 18-04-07, 04:21 PM   #7
scorpion
What if I bolt a Turbo on?
Old 18-04-07, 04:22 PM   #8
hovis
get a gixxer1000
Old 18-04-07, 04:23 PM   #9
scorpion
I was thinking of The Bonneville Salt Flats
Old 18-04-07, 04:30 PM   #10
Kate
get a gixxer1000
a gixer 600 will do
150mph @ 13k Grinch SV Talk, Tuning & Tweaking 10 25-04-06 10:01 AM
