Old 21-04-07, 10:36 AM   #1
weazelz
Default MoT question
I am selling my car which currently has 2 months' MoT remaining. I'm pretty sure it'd pass an MoT without needing anything doing to it, & that I could get a few quid more for it with a full years' MoT
so .. can I take it for an MoT, & if it fails, is the two months remaining on the old MoT still valid? is there any record that it's failed?
Old 21-04-07, 10:46 AM   #2
Ch00
Ch00's Avatar
Default Re: MoT question
IF it fails the MOT then it has failed, record is made and the points where its failed are given to you to fix. So you would lose those 2 months.
Ch00
Ch00 is offline   Reply With Quote
Old 21-04-07, 10:52 AM   #3
weazelz
thanks. fail enough, I suspected as much
Old 21-04-07, 10:57 AM   #4
Ch00
Ch00's Avatar
Also I'm not sure if you can even get it MOT'd that early, I normally remember on the day before it needs to be done !!!
Ch00
Old 21-04-07, 11:05 AM   #5
timwilky
timwilky's Avatar
Of course you can get it MOTed early. But if it passes they cannot extend it from the expiry of the previous MOT unless it is 1 month prior to the exirey date. Also if it fails, the previous MOT document is still valid, but in truth wouldn't you want to fix anything that was a fail issue before you drove it.
Not Grumpy, opinionated.
MOT Question DanDare Bikes - Talk & Issues 4 04-03-08 01:48 PM
R&G bar end question lukemillar SV Talk, Tuning & Tweaking 1 21-03-06 10:27 AM
Bhp Question kashby SV Talk, Tuning & Tweaking 4 07-05-05 11:39 AM
N.I.P. Question? Cronos Bikes - Talk & Issues 19 21-04-05 11:21 AM
