Old 23-04-07, 08:18 PM   #1
Grinch
Default Removing the Water pump housing
Am I going to have to drain the rad?
Old 23-04-07, 08:20 PM   #2
svrash
Default Re: Removing the Water pump housing
yeah and the oil cause you need to take the whole side case of the clutch side
Old 23-04-07, 08:21 PM   #3
Grinch
I guessed the oil as that was going to need doing, dam... oh well, might as well do it in one. I take it I just need to stick 'ironised' water in the rad then?
Old 23-04-07, 10:10 PM   #4
UKStreetFighter
I normally use distilled water and antifreeze mix, same as the car. I normally mix 1 part antifreeze to 2 parts water.
Or you can buy ready mixed in some places but its expensive.
Old 24-04-07, 07:28 AM   #5
Grinch
Ta, very much. Thought so, but I like to be sure of these things before I stick it all in my rad.
Old 24-04-07, 08:07 AM   #6
Viney
You wont need to drain the oil if you do the whole lot on the side stand. The sv leans enough for you to do this. However, if you feel more comfortable draining the oil, then do it. And PJ1 is the best to paint the casings with
Old 24-04-07, 10:26 AM   #7
Quite a good idea to change the oil since usually you'll get coolant contamination though...
Curvy Water pump SVDragRacer Stuff Wanted 2 22-03-09 11:58 AM
K2 Water Pump Housing andy1505 Stuff Wanted 2 06-02-08 01:33 PM
Water Pump....leak 21QUEST SV Talk, Tuning & Tweaking 9 07-11-07 09:02 AM
Water pump on VW Passat rpwoodman Idle Banter 11 08-05-06 06:15 PM
Removing water pump neuone SV Talk, Tuning & Tweaking 5 08-02-06 01:39 PM
