Old 26-04-07, 08:56 PM   #1
bugsy46
Default Honda Technician Needs Advice!! Now!!!!
Ok, so I have disassembled my sv650 curvy starter motor as it was sticking, looks ****ed but anyway after filling the street with a litre of oil its gone back on. Press the starter....... WHIZZZZZZZZ!, doesnt turn the engine over??!! Ok, Iv had a hard day at work replacing shims and testing regulator rectifiers etc, My brain is in do do mode now. Anybody know of anything I should look out for?? Could the starter motor be spinning the wrong way somehow? I dont ****ing know and its dark outside, save me the hassle and give me some clues
thanks
Old 26-04-07, 09:15 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: Honda Technician Needs Advice!! Now!!!!
When you took the starter off, did you check if the starter clutch was still ok?
Inside the hole is the starter clutch gear, try turning it, it should turn one way but not the other, if its going both ways free then its not engaging with the flywheel. Its a messy issue to resolve.
Im not sure if the starter can turn the other way, someone enlighten me if its possable with standard sv wiring.
Old 26-04-07, 09:24 PM   #3
bugsy46
nope mate, starter gear is spot on, only turns one way, I just read billy c's posts about him bumping it off then it working after? jesus this is bizzare!!! come on folks!!
Old 27-04-07, 07:01 AM   #4
Can't imagine how, short of reverse connecting the battery.
Still thinking starter clutch - as long as the motor is spinning, the relevant bits still have their teeth, and assuming all has gone back where it came from, (idler gear and shaft specifically), that's the only place that the trouble could still be.
Old 27-04-07, 07:28 PM   #5
bugsy46
Well! I put the starter motor this morning on the old battery tester and it span in the wrong direction!!! I then turned the casing the other way round and low and behold it span the right way!!! Physics huh! Go figure!!!
Old 27-04-07, 07:28 PM   #6
K
See, this is the chaos that ensues letting Honda techs anywhere near the dissembled parts of another make of bike...
... they're so used to seeing a Honda in one bit and running well that they get all lost and confused in a mess of oil and metal.
Crash.NET - Pedrosa's Michelin technician: QA. NewsBot News 0 14-08-08 12:20 PM
Crash.NET - Pedrosa's Michelin technician - QA. NewsBot News 0 14-08-08 11:20 AM
Mercedes Benz Technician: MrMessy Idle Banter 0 07-04-08 09:45 PM
Pointy Speedo Technician Req. STRAMASHER SV Talk, Tuning & Tweaking 3 13-09-07 07:10 AM
Meta Alarm Technician plowsie Bikes - Talk & Issues 3 31-05-07 09:12 PM
