Old 01-05-07, 09:55 AM   #1
dmracing
Default New chain and sprockets
Guys, im after a new set. In your opinions, which one is the best? Where is the best place to get it?
I have heard renthal sprockets wear out quicker then the competitiors... is this true?
Cheers!
Old 01-05-07, 09:59 AM   #2
Baph
Default Re: New chain and sprockets
I ordered both sprokets & chain for my 650S K6 from B&C Express. I went up two teeth on the rear (to 46t) kept the standard front (15t) & used a standard length 525 chain. £104.
I can't remember if one of them is Renthal, but I think only one of them is. Maybe the front.
If you're going to use B&C, give them a call, it's far easier than using the website, and they know their stuff. Also, a 46/15/standard chain on my bike only JUST fit, but lots of room for adjustment
HTH.
Old 01-05-07, 03:43 PM   #3
jambo
jambo's Avatar
FWIW I would put proper steel sprockets both ends. There are some very flash sprocket sets out there but anything in anodised ally is going to wear faster than decent steel. Standard chain is DID. How you treat it should matter more than the brand....
Edit: The standard OEM chain from DID is endless meaning you either cut a link off to replace with supplied soft rivit link or take the swing arm out...
Old 01-05-07, 03:50 PM   #4
TSM
The Sick Man
TSM's Avatar
Renthal front sprockets do come in steel most times.
But as jambo said steel will last far longer and looks nearly the same, if you want the fancy colour, why not paint it before you stick it on.
Chain And Sprockets squirrel_hunter SV Talk, Tuning & Tweaking 10 19-05-09 10:28 PM
Chain and sprockets pencil shavings SV Talk, Tuning & Tweaking 32 23-09-08 10:14 AM
New Chain and sprockets? gavinsky23 SV Talk, Tuning & Tweaking 14 05-03-08 12:13 PM
chain and sprockets adey Stuff Wanted 4 27-11-05 01:26 PM
Chain & Sprockets BaggaZee SV Talk, Tuning & Tweaking 23 12-01-05 07:07 PM
