Exactly what it says in the title, which is the best one?
Which is the easiest to fit? Can a plank like me fit one? REALLY? ![]() Last edited by krhall; 01-05-07 at 05:50 PM. Reason: add text |
I had a Hamicad which fitted nicely, to fit any tail tidy on a pointy you're going to need to pull off a fair few things, just the way it's designed. But it's fairly straightforward (oh, except in my case, when a screw snapped in the hole - luckily I could reach it from the other side of the hole and replaced it at a later date - it was non-essential).
I don't mind the trying to pull things off, but if I broke stuff I'd be worried about them freak out and end up with a half-built bike?????
How's the GSXR? |
I fitted an evotech to my pointy not that long ago.
From memory: Unbolt the stock tail tidy and undertray (pop rivets). Take out the toolkit (mines a K6) to allow the undertray to flex a little more. Remove the plastics on the rear end of the bike. These happily stay together & just pop the front rivets off, unbolt it all, and it'll slide on & off nicely in one whole unit. You'll also have to remove the grab rail & pillion seat lock to get the plastics off. Line up the new tailtidy, bolt it in place, pushing the undertray above it (you'll need to bend it a little to get it in, but it aint hard). Put the plastics back on, beaing careful to line up the undertray on the correct side of the plastics. Bolt & pop rivet the plastics in place. Re-fit the grab rail & dont forget to put the cable back in place for the seat lock! Unlocking your seat without it could be fun! Bolt/pop rivet the undertray back in place, fit your numberplate to the tail tidy. Put your tools away & crack open a beer ![]() I would show you pictures of my WIP fitting the tail tidy, but it'd scare you. I have a lot more wires under the tail than most people have in their house! Last edited by Baph; 01-05-07 at 08:08 PM. |
Evotech gets my vote.
Everything fitted, came with a plate and neoprene seal to cover all the holes left by removing the old fender. |
I'm not so sure that I would be able to do something like that without totally f*****g it up?
Anyone local want to help? Pictures of the fitted evotech ones would be nice. Last edited by krhall; 01-05-07 at 08:26 PM. Reason: add txt |
I wasn't really sure when I started at first, having not really worked on bikes much in the past. Once I got started it was simply a matter of "Yes, it will go back together again!"
See here. NOTE: Any pictures that say WIP in the title, please close your eyes. I gurantee I have more wiring than you do! |
Evotech was very easy to fit, I went to Alford to see them and get my tailtidy.
They explained the confusing(which actually wasn't that confusing at all)part of fitting that people ask about. Plus they gave me a discount when I mentioned the org. ![]() |
#9 |
Baph - I'm not so sure I've seen some of your posts and you sound pretty handy to me!
#10 |
Electronically, yes, I'm fine.
Mechanically, nope, I'm a muppet. I was worried the first time I removed the oil filter for example. I'll attack my dads car quite happily with the wrong end of a screwdriver, but I'm far more cautious about the bike. Take the plunge, you'll do fine. I've been sort of planning to do step-by-step guides for the maintenance/upgrade work that I do, sort of from a newbie point of view. |
Curvy tail skirt or tail tidy | mouldy | Stuff Wanted | 3 | 21-02-09 12:49 PM |
My **** - tail tidy | Wideboy | SV Talk, Tuning & Tweaking | 121 | 01-09-08 06:10 AM |
tail tidy joy! | kwak zzr | Bikes - Talk & Issues | 21 | 12-08-08 09:38 AM |
Tail Tidy. Tail Tidy...Sell me your Tail Tidy.... | 1world2wheels | Stuff Wanted | 7 | 15-07-06 10:09 AM |
k4 tail tidy | joe650s | SV Talk, Tuning & Tweaking | 4 | 24-01-06 09:09 AM |
