Old 04-05-07, 06:03 PM   #1
aarond
Default Help please! (hot grips)
OK i know there are multiple threads and full fitting instructions for the oxford hot grips but i am still having problems got off old grips easily and started to dry fit the non throttle side grip using wd40 to lube it push it on very very hard a little then using a rubber mallet got it on until was about a cm till properly on however could get it any further and i was hitting v.hard now am i just being a tart and should i hit it harder or does some sanding need done. BTW the bike is a 1999 curvy thanks
Old 04-05-07, 06:06 PM   #2
hovis
Default Re: Help please!
sounds like it should go on futher
Old 05-05-07, 12:55 AM   #3
kcowgergmm
Default Re: Help please! (hot grips)
try isopropyl alcohol
Old 05-05-07, 09:49 AM   #4
tomjones2
I fitted some to my kwak z750 and although they were a snugger fit certainly no mallets were invloved.
Depending on what you mean by very hard but i dont think the insides of the hot grip are going to love being hit hard.
Stupid question but the insert they give you in the box isn't still inside the grip is it (sorry cant remeber if this is for the throttle or left side)
Also not sure that you want to take any material off the bar, or take any to much off the inside of the grip, you might expose the wiring.
Have you checked to see if the grip looks like it has some sort of manufacturing fault?
Old 05-05-07, 11:31 AM   #5
Baph
They should be flush against the switchgear on you bars/clip-ons.
Don't worry too much about hamering the grip. Personally, I doubt it'd help much to get them on, but it shouldn't damage the wiring inside the grips.
I just used glue & a lot of elbow grease. Minus the glue to remove them again.
Old 05-05-07, 11:34 AM   #6
aarond
eventually got them on sanded the bar and the grip just a little and could get it on with a bit of elbow grease throttle side was a easy in comparison thanks for your help.
Old 05-05-07, 08:06 PM   #7
hovis
how hot are they?
& what bike are they on?
Old 05-05-07, 11:03 PM   #8
kcowgergmm
Are hot grips better or would you just use heated gloves i am going to be doing one of the above for next winter.
Old 06-05-07, 10:14 AM   #9
Tomcat
We also found this a bast**d of a job, did you use the glue that was supplied? I hope not else you are in trouble now! Anyway, pure brut force was reqiured in the end ..... hope to never do it again! (But they are great when working!)
Old 06-05-07, 01:00 PM   #10
aarond
how hot are they?
I find them hot, had them on today but had to switch them off as was too warm even on the lowest setting, they are on an 1999 sv650s
are hot grips better or would you just use heated gloves i am going to be doing one of the above for next winter
I have never had heated gloves but i did have heated grips on my old bike an xj600 and i went up to just North of Aberdeen on my bike late February early march from Lincoln about 450 miles( ok not that far but the furthest i have ridden in my short biking experience!) and my hands were nice and warm all the way even in the heavy rain! heated grips get thumbs up from me
no didn't use their glue after having it unstick when i was on my old bike i learned from my mistake!!
Gel Grips SAMMY650 SV Talk, Tuning & Tweaking 3 10-07-08 09:36 AM
SV Gel Grips RRP £14.99 Yours for £13.00 SAMMY650 For Sale - SV's and SV related items 0 08-07-08 11:00 AM
Hot Grips metalmonkey SV Talk, Tuning & Tweaking 40 03-11-07 12:28 PM
Hot grips yorkie_chris SV Talk, Tuning & Tweaking 18 02-11-07 10:18 PM
Hot Grips andyb Bikes - Talk & Issues 21 20-09-07 02:23 PM
