Old 05-05-07, 09:41 PM   #1
Quiff Wichard's Avatar
Default put goodridge braided on now no brakes at all.
just thought I would let u know..!
looks like it gonna be a day of bleeding brakes for me tomoz..!
I have done a search on here- and htere are so so many different ideas about bleeding brakes.. .
I am hoping that overnight some air will pop out .. right now theres nuffin - back brake right down and front back to bar.. so i dont think zip tyin them back will help will it.
worried I have done summat now.. and I got a ride out monday -
Old 05-05-07, 10:23 PM   #2
Balky001
Balky001's Avatar
Default Re: put goodridge braided on now no brakes at all.
bleeding brakes! They are a pain. If you have no air leaks then zip tie the lever anyway and make sure the master cylinder is also bled. I hate bleeding brakes.
SV650SK3 - GSXR600K2 - GSXR750K6 - ZX636RC1H - HD Sportster 1200 - CBR600F 2012 - GSXR1000K7 - Triumph Bonneville T100 2019 - Aprilia Tuono 660
Balky001 is offline   Reply With Quote
Old 05-05-07, 10:47 PM   #3
Baph
Quiff, if you're fed up with bleeding in the morning, do it the reverse way around.
Strong syringe (I use the Mity vac) & push brake fluid up from the bottom, watching the res as you fill. Once you see fluid, assuming you're starting from completely empty lines (or as near as damnit), then top up a little & bleed as normal.
Always works for me anyhow.
Old 05-05-07, 11:13 PM   #4
That's my way too, easier to push air up than push it down. I hate bleeding brakes...
Old 05-05-07, 11:18 PM   #5
Luckypants
Luckypants's Avatar
Posted elswhere and earlier on this thread, tie the lever back to the bar overnight. The magic brake fairies come and sort it out for you (well they did mine!)
Old 06-05-07, 12:40 AM   #6
I read all these ideas on a search-
I have no syringe.
ha ha
cant sleep for worryin in case I cant get it done tomoz. dam dam
I put brand new hoses on
never have done before.. just changed brake pads.. and managed to bleed ok before.. but this is a bit different.
Old 06-05-07, 01:07 AM   #7
Razor
I take the calipers off, clean them and then push the pistons back, means less space for the air to fill up. Then I use my trusty medical waste syringe and push the fluid into the lines. Once I've got the reservoir full I bleed as normal.
I fitted a 3 line set a little while ago and the longest part was popping the rear RHS panel off to get at the rear brake reservoir.
Old 06-05-07, 01:25 AM   #8
When i did my lines the first time, it took me aaaaaages. No clever tools, just a bit of hose and a powerful dose of sunburn. Probably, I'd say, the most frustrating and difficult job I've ever done on the bike, particularily since when it finally came good I wasn't actually doing anything different to what I'd been doing for an hour. That's annoying, if I was doing it wrong that's fine but when you're doing it right and it just isn't working, then it suddenly does...
But, I did get it done, and back then I knew nothing
Old 06-05-07, 08:38 AM   #9
John Burt
Try bleedimg the master cylinder forst, USE A CLOTH to catch the fluid, back off the banjo and bleed the cylinder then carry on as normal - please don't get any fluid on your paint. Top Tip have a bucket of water standing by - if you spil fluid on the bike chuck the bucket of eater over it should wash it away and prevent the paint marking.
Old 06-05-07, 09:19 AM   #10
hovis
i remember the good old days trying to bleed moto-x brakes tis a nightmare
thats why i got my braided hoses fitted at a garage
Goodridge Braided Hose Sets SV-net SV Talk, Tuning & Tweaking 15 25-07-08 11:29 PM
Braided hoses - Goodridge or Hel? Tim in Belgium SV Talk, Tuning & Tweaking 30 06-02-08 09:43 PM
goodridge braided breaklines ginge For Sale - SV's and SV related items 15 16-04-07 03:38 PM
Goodridge hoses Razor For Sale - SV's and SV related items 4 11-03-07 11:10 AM
Servicing my brakes and fitting braided lines Grinch SV Talk, Tuning & Tweaking 20 09-02-07 02:06 PM
