Bodywork Post your own reviews, opinions and experiences on this subject.
Old 07-05-07, 10:20 AM   #1
maff
Default how do i....?
remove the lower fairing from me bike?
i tried to it the other day, removed all the bolts and then the thing wouldnt budge...
help please
maff
Old 07-05-07, 02:17 PM   #2
hovis
Default Re: how do i....?
what lower is it?
did u undo the bracket
Old 07-05-07, 05:36 PM   #3
maff
its the full side panels. took out the four bolts either side and nowt moved
Old 08-05-07, 12:34 AM   #4
MiniMatt
Guessing here as I only have a belly pan, not the full kit - but does it lock into the belly pan? Ie. do you need to remove the belly pan first?
Also, might help narrow down the prob, is it a pointy or a curvy?
Old 08-05-07, 07:59 AM   #5
hovis
if its got lowers it wont have a belly pan
i will go & have a lot at mine but, there is a bracket holdinig it on wwich you can only see from behind
Old 08-05-07, 08:13 AM   #6
hovis
have you undone the bar on the rad>
i think you have a pointy, so not sure if its the same ?
Old 09-05-07, 12:01 PM   #7
maff
ive given up on that. only wanted to see if i could do (being the most unmechanical person in the world)
so i fitted my hugger instead
