Old 09-05-07, 07:01 PM   #1
Red ones
Red ones's Avatar
Angry Bike dead
Rode home fine. Stopped engine - fine. Went to restart nothing - no lights, no sounds, no nothing.
Battery is fine, fuses fine.
any ideas?
I have checked all the connectors I can see - fine, not visible signs of chafing on wires.
Old 09-05-07, 07:15 PM   #2
Biker Biggles
Biker Biggles's Avatar
Default Re: Bike dead
Battery connections/Earth strap or ignition switch fault.Try putting the steering lock on,putting the switch in park and see if the parking light stays on when you take the key out.If nothing then check those battery connections again.
Old 09-05-07, 09:45 PM   #3
Spiderman
Where the hell am I?
Spiderman's Avatar
kill switch? lol, wouldnt be the first time someones overlooked that little beauty.
Old 09-05-07, 10:03 PM   #4
Jester666
Never happened whilst anyone was watching!!
Old 09-05-07, 10:37 PM   #5
TSM
The Sick Man
TSM's Avatar
Err, the lights would still work even if the kill switch was flicked.
Old 10-05-07, 06:46 AM   #6
Red ones
Red ones's Avatar
Not the kill switch, not the battery connections, not the main fuse, not he ignition fuse.
I think I have a duff ignition keyswitch!
Bugger. Time to call the recovery vehicle!
Old 10-05-07, 08:51 AM   #7
SV650Racer
Are you sure you have checked all the fuses?.
There is also a connector under the left hand seat panel that if loose will do this..although it shouldnt come loose unless you have taken a panel off and caught it.
Old 10-05-07, 09:02 AM   #8
Grinch
How about the starter relay?
Old 10-05-07, 10:48 AM   #9
Red ones
Red ones's Avatar
It's not that either.
(Beginning to feel like the start of Hong Kong Fooey...
...is it the mild mannered janitor?)
Old 10-05-07, 10:54 AM   #10
Grinch
There is a bit on it that tends to rust through just below where the 30amp fuse plugs in...
Dead Bike. Grinch SV Talk, Tuning & Tweaking 21 07-01-09 11:52 PM
My bike is dead shonadoll Bikes - Talk & Issues 12 14-08-08 10:08 PM
Dead Bike... MidgetMoose Pennine Massive 6 07-09-07 07:22 AM
Help - Dead Bike. mdcvjd SV Talk, Tuning & Tweaking 6 19-07-07 02:32 PM
Dead Bike seandixie Bikes - Talk & Issues 24 07-10-06 03:11 PM
