Old 24-05-07, 11:53 AM   #1
plowsie
Default Fork Maintenece
Quickly before lunch someone tell me what would be likely to be needed to be done on my front and rear forks, the bike hasnt had no loving for at least 3500 miles.
cheers
Stu
Old 24-05-07, 11:59 AM   #2
Baph
Default Re: Fork Maintenece
Your bike has rear forks?? They'll need removing & replacing with a shock...
As for maintenance, not a lot needs doing unless they've started to rust a little.
Maybe replace the oil if you're taking them out to clean them a little too. Handy tip, tip-ex on the top of the forks & the top yoke for alignment. Even if you think they're straight, they might not be & it would completely screw the handling if they weren't put back in the exact same way they were taken out.
Old 24-05-07, 12:00 PM   #3
jambo
jambo's Avatar
After 3,500 miles they should be fine.
Let us know when the fork oil was last replaced (if ever) and what, exactly, you are feeling.
Old 24-05-07, 11:59 PM   #4
kcowgergmm
how often should fork oil be replaced?
Old 25-05-07, 04:52 PM   #5
andyaikido
Never did mine in 20,000 miles but you might feel the benefit every 10,000 or so.
Good opportunity to tailor the spring rate and oil weight to your riding location/style and weight too.
Has anyone ever heard of or seen a fork slider save a fork-track or road (Not SV!) monkey Bikes - Talk & Issues 8 28-10-07 11:59 PM
just fork oil leemole SV Talk, Tuning & Tweaking 4 15-08-07 01:22 PM
K4 fork spares, damper tubes,preload adjusters,fork lowers ianofbhills For Sale - SV's and SV related items 11 13-03-06 06:58 PM
How much fork oil do you need and where to buy ?? SpankyHam SV Talk, Tuning & Tweaking 2 14-08-05 08:02 PM
Fork OIL - which one ? SpankyHam SV Talk, Tuning & Tweaking 5 28-07-05 06:42 PM
