Old 24-05-07, 12:21 PM   #1
Pedrosa
Default Mine is bigger than yours!
Ah ha my SV friends....now that I be have your attentions.
A maybe silly question for you,but answer would be most very welcomed.
Does anybody knowing how can find which size valve(diameter as oppose length) fits any given motorcycle wheel or scooter wheel?
I really not able find this information.
I thanking you very far in advanced for your assitances.
Old 24-05-07, 12:22 PM   #2
Steve H
Default Re: Mine is bigger than yours!
Doesn't anyone from HRC know? Now that does suprise me.
Old 24-05-07, 12:24 PM   #3
Pedrosa
Mr.H...Mechanics in HRC do not know answer as they never having to fit tyres.They simply change wheels. Surprising you not knowing this?
Old 24-05-07, 12:26 PM   #4
Steve H
Silly me.
Old 24-05-07, 12:28 PM   #5
Alpinestarhero
HRC would only supply something that would further mess up the handling of the RCV this year
My tip dani, one my father always tells me. If it aint turning enough for you, just push on the inside handlebar, you'll make it round a treat!
Matt
Old 24-05-07, 04:01 PM   #6
A standard tubeless valve goes in a hole 11.5mm diameter, (cars and bikes of my knowledge anyway, othe stuff may be different). A typical valve is a 'TR412' 20mm length. Other lengths are available depending on application, but generally on a bike wheel, particularly the front 'cos of the discs, the shorter the better.
An example of a '412': "http://www.tyrebaydirect.com/7-Standard_Snap_in_Valves/124-TR412_22mm_length_x_100.html"
Old 24-05-07, 04:33 PM   #7
Pedrosa
Mr.Squid...I was know you not be let me down. No need to even be asking...a T shirt is on it way to you. I will also see if I can organisinf pit pass for you to come and say hola when Moto GP in UK.
OK, even bigger problem dmracing SV Talk, Tuning & Tweaking 2 19-04-09 08:49 AM
That went well... Shall we try something bigger? northwind SV Ecosse 50 17-10-07 05:50 PM
Am I shrinking, or is everything else getting bigger? K Idle Banter 41 14-07-07 05:44 AM
A bigger bike wyrdness Bikes - Talk & Issues 3 15-02-07 03:22 PM
Mine All Mine!! - Finally 454697819 Bikes - Talk & Issues 14 27-12-04 11:12 AM
