Old 28-05-07, 08:19 AM   #1
muzikill
muzikill's Avatar
Default Weathers better today isn't it?
Thinking of going oot fer a scoot (as soon as my stomach has settled down from being in the pub last night - watched a stone roses tribute band and they were great!)
haven't seen the weather on sky yet to make my mind up.
Old 28-05-07, 08:32 AM   #2
kitkat
Default Re: Weathers better today isn't it?
well its lovely in the west
Old 28-05-07, 08:38 AM   #3
husky03
Yes its nice- but i've got the wee man as the mrs is away with the baby and her mother shopping-plus i've got a bent gear linkage rod so having to source a replacement today!
husky
Old 28-05-07, 09:47 AM   #4
Tiger 55
The further north and west (and the earlier you set off!) the better the weather today. Or so they say...
Old 28-05-07, 10:33 AM   #5
jim@55
yep,, its nice but my bikes in bitsso im not going anywhere
Old 28-05-07, 02:28 PM   #6
muzikill
muzikill's Avatar
Just back in - weather was great went over dukes pass for the first time today! amazing - although i did spit at the holiday home place half way along (some people have way too much money)
Bit of an off today Well Oiled Bikes - Talk & Issues 19 19-12-07 12:58 AM
anybody out today? sat 9th hovis South & West Surfers 8 10-06-07 09:56 PM
So where did you go today then? Ed Bikes - Talk & Issues 22 04-12-06 11:15 AM
My wee run today! Beaniebike SV Ecosse 9 09-07-06 09:02 PM
So where did you go today then? jimmy4237 Idle Banter 19 09-01-70 04:52 AM
