Old 31-05-07, 10:47 PM   #1
sfstu
Default loose throttle cables???
hi guys..my throttle cables ( where they come out from the accelerator/brake bit on bars, ) run through two small metal tubes and these seem really loose to me... throttle works fine and returns fine but as i say, they seem loose
are they supposed to be that way..?
should say its a k4nekkid and yes i've put renthals on !! had to re-route the throttle cables through engine do it but had a mate help me and it went ok...
any help or advice would be much appreciated....
Old 31-05-07, 10:50 PM   #2
Default Re: loose throttle cables???
Yes they are bit wobbly aren't they?
As long as their securings are err... secure, then everything is OK.
Old 31-05-07, 11:02 PM   #3
sfstu
yeah checked the screws holding em onto the handlebar thingy!? and they're tight...
Old 01-06-07, 01:14 AM   #4
clm2112
Uh..do they look like this? (I've pulled the black rubber dust boots back in this photo to show the adjusters inside them.)
If so, they can, and should, be adjusted.
The nut in the middle of each one is the locking nut, loosen it. Then unscrew the the other two to make the throttle cables tighter. Then, tighten up the locking nuts again.
The purpose of these two adjusters is to take all the slop out of the throttle grip. I adjust the pull cable first, making the adjuster longer until I can feel the throttles opening with just the slightest pressure on the grip. Next I adjust the return cable adjuster to take any wiggle room out of the throttle grip.
Last, check and make sure the throttle will snap shut when you let go of the grip. (You can get the cables so tight that the springs on the throttle body can't close the throttle on it's own. Check it with the bars against the stops on either side!
I think you'll like the feel of the throttle with the cables properly adjusted. Nice and crisp with good feedback to your hand.
There is also an adjustment on the clutch cable that works the same way, only the clutch is just a pull cable (no second return cable). It can, and should, have the slack taken out of it as well. Again, don't get it too tight, or you'll be taking off pressure from the clutch plates.
Old 01-06-07, 06:45 PM   #5
sfstu
thanks for the info... its not the adjuster nuts but above them...the cable runs into a metal tube and this is the bit that seems loose...? sorry, got no idea how to put pics on here... !!!
Clutch cables/Throttle cables Curvy 21QUEST For Sale - SV's and SV related items 0 05-08-08 08:45 AM
Other throttle cables to fit curvy SV ? Stig SV Talk, Tuning & Tweaking 0 19-01-08 01:34 PM
Where Can I Get A Pair Of Throttle Cables? squirrel_hunter SV Talk, Tuning & Tweaking 11 12-06-07 09:06 PM
Someone cut my throttle cables! SVeeedy Gonzales Bikes - Talk & Issues 42 29-03-07 12:16 PM
Throttle Cables ugp Stuff Wanted 7 30-12-06 12:15 PM
