Old 01-06-07, 12:07 AM   #1
skulpt
Question Got a front end!
It was free off a mate, but i need to know if it will fit? its off a 1992 GSXR 400. I will need different brakes i know but what about fitting it to my bike? Im sure ill need stiffer springs too!
Old 01-06-07, 07:37 AM   #2
stewart-250
Default Re: Got a front end!
This is a front end I've been mulling over for a while myself but have done nothing about as yet. Your forks were fitted to GSXR400, Bandit400 & RGV250 that I know of and look very similar to curvy sv items. Same diameter (41mm) as sv so will fit stock yokes, seals are same part number as a curvy sv. Not sure about length though, are they the same length as an sv fork?
Big advantage over sv forks would be having the Tokico 4 pot calipers, although the master cylinder would probably need changing to a larger bore one. The EBC brake catalogue shows the Curvy SV has the same discs as the 88-90 GSXR the 89-94 Bandit 400 and the 88-90 RGV 250.
Lots of similar parts so I'd just have go and fit your new forks to see what parts you need to change.
Let us know how you get on.
cheers
Stewart
Old 01-06-07, 02:39 PM   #3
skulpt
Cheers matey, will do!
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
SV650s 2000 model, yellow. I need front central and front right fairing. OdySV Stuff Wanted 0 25-02-07 04:47 PM
K3 radiator(any condition), front header pipe, FRONT END!!!! buttmunch Stuff Wanted 1 10-04-06 10:09 PM
