Old 06-06-07, 02:23 PM   #1
cmit37
Default installing stainless steel braided brake lines
Hi,
I just received my stainless steel braided brake lines and will be replacing the original ones tonight. I am not entirely sure about the best way to do this and was hoping that I could have your comments on my intended procedure.
I have a bleeding valve tube combination that should allow me to pump out the brake fluid.
1) connect the bleeding valve/hose to the bleeding nipple on the front right caliper;
2) Unscrew the bleeding nipple;
3) Pump the brake lever until no more fluid is coming out;
4) Close the nipple;
5) Connect valve to front left caliper's nipple;
6) Pump until no more brake fluid is coming out and close nipples;
7) Unscrew the brake line fittings;
8 ) Attach the new lines and fittings;
9) Open the master cylinder and fill with brake fluid and cover;
10) Connect the bleeding valve to the front right brake calliper's bleeding nipple and undo nipple;
11) Pump until no more air bubbles are coming through the valve making sure that there is enough fluid in the master cylinder.
12) Repeat step 11 for front left caliper;
13) Secure the cover on the master cylinder and pump it up until there is enough grip in the front calipers.
Did I miss something?
Thanks
Old 06-06-07, 02:32 PM   #2
Baph
Default Re: installing stainless steel braided brake lines
From what I can see that would do the job, but I'd change the last few steps.
I'm assuming you mean open reservoir? If you don't do this from the start, you'll find it mighty hard to bleed all the fluid out the system.
My version, skip 9.
10) Connect the bleeding valve to the front right brake caliper bleeding nipple and undo nupple;
11) Pump brake fluid INTO the caliper (using the bleeding valve), to push the fluid from the bottom up. Stop when fluid appears in the resevoir & before you get it all over your paint. Then suck fluid out again until it's at the VERY bottom of the resevoir. Dont forget to close bleed nipple (I've forgotten that before now!!).
12) CAREFULLY repeat 11 for the left caliper. All you're doing here is ensuring that liquid got to the left side when you pumped it into the right side.
13) Top up the resevoir with fluid.
14) Check brakes, and bleed as needed to get pressure in the lever. Top up with fluid as needed. You'll probably find you check the brakes, and they're fine. I usually do.
Old 06-06-07, 02:35 PM   #3
stuartyboy
Just a thought but did they come with installation instructions for your bike?
Old 06-06-07, 02:37 PM   #4
cmit37
I take it I need a syringe to pump the fluid into the caliper??
Old 06-06-07, 02:38 PM   #5
cmit37
All the installation instructions say is to consult the manufacturer's manual.
Old 06-06-07, 02:44 PM   #6
Baph
That's why I bought a MityVac. A nice bi-directional pump. It'll blow or suck, whatever takes your fancy (careful now!). Also has a little bottle inline to catch fluid coming out the calipers.
About the instructions, that's just to cover themselves, they don't want to miss something & cause ijit to ride on a bike with effectively no brakes.
Old 06-06-07, 04:20 PM   #7
andy
Best hint I have even been given for fitting new lines, it was from a dealer who sold Hel lines, was to use a syringe (a few pennies from a chemist) to suck fluid from the caliper - just keep filling the reservoir.
Does the job very well in about 20 seconds with very little need for traditional bleeding.
Old 06-06-07, 04:21 PM   #8
andy
You can also use the syringe as a neat way to remove fluid from the whole system before you split it - just suck it straight out the caliper bleed nipple.
Old 06-06-07, 04:26 PM   #9
andy
So, to rewrite your instructions:
Use syringe instead.
Just suck - ooooer
Yes, otherwise step 5 and 6 wont work
Syringe
Dont bother closing the left nipple
You mean reservoir - it should be opened at the begining and left open (but covered to stop dust etc...)
Already undone on left, connect syringe
Just suck and keep eye on level
12) Repeat step 11 for front right caliper;
Yup
Ermmm, no, do a traditional bleed on both calipers and then put lid on after topping up.
Job done.
Old 06-06-07, 04:29 PM   #10
cmit37
Thanks for the suggestions. I now feel more confident to attempt the job.
Braided brake lines Spokey Stuff Wanted 13 29-09-08 07:36 PM
Stainless Braided Brake Lines (Pointy) svdemon Stuff Wanted 2 15-07-08 09:13 PM
HEL Stainless Brake Lines svdemon For Sale - SV's and SV related items 7 18-03-08 07:03 AM
Stainless steel Brake lines for a Pointy neio79 For Sale - SV's and SV related items 2 30-01-08 08:44 PM
braided brake lines adey Stuff Wanted 2 22-11-05 09:16 PM
